| Smoto Bob |
 Smoto Bob World Chat Champion
 Posted: 14:12 - 15 Nov 2004 Post subject: Stupid Mechanic Numptyness?? |
Took the rear brakes apart on my dt/tdr thing to try and work out why they were making such a metalic noise, and well i found it hilarius that the last owner had inserted a pad around the wrong way
(ie one was facing way from disk)
Can any one top that?  ____________________ F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 14:18 - 15 Nov 2004 Post subject: |
Yeah some twat I know tried to fit a Dt wheel in a TDR
 ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| map |
 map Mr Calendar
 Posted: 14:19 - 15 Nov 2004 Post subject: |
Bike was riding rough with no acceleration so pulled into (local-ish) motorcycle dealer. Mechanic there tried to convince me that the big end had gone - major work/new engine & mega money.
Turns out one set of coils gone and only running on 2 cylinders - fixed for £20 from breakers.
Funny enough I don't let them do any work on my bike, although unfortunately they're rather convenient for MOT test. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Smoto Bob |
 Posted: 14:21 - 15 Nov 2004 Post subject: |
| stinkwheel |
 Posted: 15:21 - 15 Nov 2004 Post subject: |
You should've seen the wiring on my CB125TDC when i got it.
Someone had removed the fuse (presumably because it kept blowing due to an intermittant short they had created in another place) then twisted the ends of the wire together and stuck them down with eloastoplast I shit you not!
The worst bodge I have ever seen was on my mate Ants BMW ratbike. All the worse because he knew exactly what he was doing. One of the lugs on the fork stanchion snapped off meaning he had nothing to secure his brake caliper to. As the bike was due an MOT the next day, he made a new one using plastic metal and painted over it. It somehow passed the MOT like this but he dared not use the front brake at all as it would have snapped off. He turned up at a rally later the same day having ridden around 200 miles (including motorway) with no front brake and all the wiring pulled out of the headlight because he had a 'little fire' on the way over.
Class act.  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Git |
 Git Brolly Dolly
| skyline |
 skyline Scooby Slapper
| Smoto Bob |
| Kickstart |
 Kickstart The Oracle
 Posted: 16:18 - 15 Nov 2004 Post subject: |
We had a headlight dipped beam bulb go in Charlottes car. Stopped at a garage and changed the bulb, with no effect. At the weekend had a bit more of a poke around and still could not find the problem. Following weekend had more of a poke, checking wires, swapping relays, checking the supply in the fuse box.
Eventually realised I had changed the main beam bulb . New dipped beam bulb and it worked fine.
| Minky_monkey |
 Minky_monkey Traffic Copper
 Posted: 16:36 - 15 Nov 2004 Post subject: |
One of my mates has a fetish for cable ties. No jobs complete without at least one being used!  |
| nick.h |
 nick.h World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
| Gazdaman |
 Gazdaman I did a trackday!!!
| stryker |
 stryker Brolly Dolly
 Posted: 09:59 - 16 Nov 2004 Post subject: |
When I bought my FZR I took it for an MOT. It was pulling terribly. The stuck up arseholes who ran the garage hated anything that wasn't british, told my the bike was a knacker. I decided to turn them down on a carb rebuild, took it home.
I found one of the HT leads was off the spark plug. Put it back on, bike ran clean and sweet as a nut.  ____________________ Now what? |
| Demonic69 |
 Demonic69 The Pink Rhino
| tatters |
 tatters Exxon Valdez
 Posted: 11:18 - 16 Nov 2004 Post subject: |
ZZR600 - pervious owner had re-sprayed the bike with the fairing still on the bike getting red paint all over the frame and engine so had then sprayed sliver paint on the engine/frame and getting silver paint on the red paint on the fairing and then because he had got red and sliver pant on the radiator and cockpit he sprayed them black which got black paint on the frame and fairing
AF1 125 - previous owner re-built the whole engine with instant gasket including the cyclinder head gasket, and used a mixture of metric fine and imperial nuts and bolts forced on the bike. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Adam_P |
 Adam_P World Chat Champion
 Posted: 11:37 - 16 Nov 2004 Post subject: |
KE175 prat about bike when I was a kid. Dad brought it home, sat on the drive. Thought to ourselves, we better have a go then.
Sat for 30 fooking minutes trying to get the bloody thing to start. Quick check over of wiring showed that previous dipstick (who had been using it for daily commute) had managed to wire the headlight wiring into the earth for the kill switch, so when we had the lights switched on - no spark..!
Luckily my old chap is an electrician and he stuck his tester over the rest of it before we tried again. It was a bitch to kick start at the best of times anyway! ____________________ Colin McRae MBE 1968 - 2007 RIP
Orwell Rolls in his Grave
God is imaginary |
| nick.h |
| nick.h |
| divuk83 |
 divuk83 World Chat Champion
 Posted: 21:31 - 16 Nov 2004 Post subject: |
Using nyloc nuts on an exhast stub is a classic one.
Dave |
The last post was made 21 years, 189 days ago. Instead of replying here, would creating a new thread be more useful? |
