How do I remove the RC/Power Valve??
xenepp
PostPosted: 22:14 - 02 Jan 2005    Post subject: How do I remove the RC/Power Valve?? Reply with quote
Hi guys,
So I finally decided to get a new engine for my ailing '94 NSR125F. It's a 2000 engine which has caused MANY complications, including a new cylinder + piston due to the exhaust port having been cracked (off a crashed bike) but I'm down to taking out the RC valve/exhaust power valve off.
The rubber seal's come off (after much persuasion) but the damn spindle (valve shaft)'s just not budging. On my new cylinder head the recess doesn't have a thread on it, so I'd imagine the old one doesn't either.
I found an exerpt from a Haynes manual, but it just advises to remove it.... BUT DOESN'T SAY HOW!!!
ahem..
Anyone have any ideas (or know what I mean)?
Thanks,
-Joel
mr jamez
PostPosted: 23:27 - 02 Jan 2005    Post subject: Reply with quote
Just pull it out, once you remove the dust seal there is nothing else to hold it in, mine just slid straight out. The only thing I can think of is that the valves are seized onto the shaft because of carbon build up and are stopping it from coming out, spray a loaf of WD40 or soak it in something for a while to free it up.
Remember to remove the little metal collar from the old barrel and install it in the new one otherwise the spindle will go too far in and get stuck.
xenepp
PostPosted: 23:22 - 03 Jan 2005    Post subject: Reply with quote
Mr Jamez, you are 100% spot on! I basicly stuck the wedge underneith the thread (NOT the thread!) in a vice and tapped the old cylinder with a hammer (my new best friend) untill the little bugger slid out, and man, there was such a build up of carbon on there that I had to scrape it off before I could get the valves out!!
Top marks!
Thanks LOADS lads Wink
-Joel
The last post was made 21 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.42 - MySQL Queries: 14 - Page Size: 35.76 Kb
