Adjust chain tension
Polarity
PostPosted: 15:05 - 27 Dec 2004    Post subject: Adjust chain tension Reply with quote
Just wondering if anyone could tell me how to adjust the chain tension on an honda nsr 125 rr.
Flip
PostPosted: 19:50 - 27 Dec 2004    Post subject: Reply with quote
It's in your handbook mate Thumbs Up
Make sure the centre of the chain at the bottom is the tightest part! Then...
Loosen the axle nut. (big nut on left side)
Loosen the 'lock nuts' (There are 2 bolts at the rear of the bike, one on each arm. 2 nuts on each bolt. The nuts furthest from the bike are the locking nuts.) 10mm I think.
The 2 nuts nearest to your bike are the 'adjusting nuts' (One each side) Turn them clockwise to tighten and anti clockwise to loosen.
Each 'adjusting nut' has to be turned an equal amout of times eg. if the left nut is turned twice, the right must also be turned twice.
Proper slack for your bike is 30 -40mm.
Tighten 'locking nuts'. (Use two spanners, one to hold the adjusting nut in place and one to tighten the 'lock nut')
Tighten axle nut.
Lubricate.
This should be done every 600 miles Thumbs Up
Ask again if this isn't very clear Thumbs Up
The last post was made 21 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.36 - MySQL Queries: 14 - Page Size: 31.52 Kb
