er5 making whistling noise
greenmeanie
PostPosted: 21:40 - 11 Jan 2005    Post subject: er5 making whistling noise Reply with quote
ive just bought an er5 and had it restricted to 33bhp. it has just started making a strange whistling noise which appears to be coming from the carb area. is there any link? ive checked engine oil. Crying or Very sad
Rh.
kasandrich
PostPosted: 23:09 - 11 Jan 2005    Post subject: Reply with quote
Are you sure its not the exhaust????
This is a feature! if you have the engine running and just place your finger in the exhaust gas flow as it comes out of the exhaust you can vary/stop it.
It is apparently to do with the baffles in the exhaust, and most of them do it......Andy's certainly does.
If it really is from the carb area, I'd say it sounds like the carb hasn't gone into the manifold rubber properly or the carb into the airbox rubber, this is likely to cause lean running on one cylinder, and could be a problem in the long term.
In short....exhaust no problem, but if it is coming from carb/s get it back and get it checked by the dealer who restricted it.
Richard
CBR1000FM
greenmeanie
PostPosted: 22:04 - 12 Jan 2005    Post subject: Reply with quote
sorted it mate. turns out it was in the carb area. one of the rubber washers restricting it was bent over making an air gap. took it back to dealers and it took 10mins to sort Razz
Rh.
kasandrich
PostPosted: 22:33 - 12 Jan 2005    Post subject: Reply with quote
Wink Wink
Richard
CBR1000FM
The last post was made 21 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.09 - MySQL Queries: 14 - Page Size: 39.58 Kb
