| Author |
| stinkwheel |
 Posted: 20:43 - 16 Jan 2005 Post subject: How to join wires |
There is nothing more annoying than spending many hours going through your bikes loom looking for a wiring fault to find that it has been caused by someone elses poor quality joints.
I will go over a couple of common ways to join wires, they have pros and cons but they should ensure a good contact.
PVC tape should only be used to insulate a join as a 'get you home' bodge or as a temporary measure prior to doing the job properly.
Solder
Ensures a good, strong, permanent and highly conductive join between two pieces of metal. There is a 'How to' on soldering on my website so I wont go into that here. It is ideal for splicing a new piece of wire in or for conecting rigidly to fixed componants. It should be noted that when one side of a soldered joint is fixed and the other end is flexible, you can get fatigue just above the joint which can cause the cable to break, in these cases, use a crimp.
Soldered joints should be insulated using shrinktube.
Soldered joint
https://www.bikechatforums.com/download.php?id=10634
Insulate with shrinktube
https://www.bikechatforums.com/download.php?id=10636
Pre-insulated crimps
These are readily available in garages and auto shops. The insulation is already attached to the crimp on terminal. Spade connectors are commonly used but bullet and ring type terminals are also available along with butt connectors for joining two pieces of wire more permanently. It is important that you strip the wire in such a way as the crimps will get hold of both the insulation AND the wire.
There are three different sizes, coloured yellow, blue, then red in decreasing order of size, match these to the size of the wire you are using.
It is ESSENTIAL to use the correct crimping tool to attach these terminals. Using a pair of pliers will NOT turn the ends of the crimp in the correct way and the connection will be loose, a correctly crimped terminal should be almost impossible to pull off by hand and the insulation remains securely attached. Cheap crimping tools cost less than three pounds (see picture) You use the colour coded bit at the open end of the pliers shown. With this type you need to aply two crimps per terminal, one over the bared ends of the wire and the other over the insulation.
If you are doing a lot of wiring, it is worth buying a specialist ratchet crimping tool, this does a much quicker and better job by applying both crimps at once.
This type of terminal is really designed for use on car wiring which is well protected from the weather, they will corrode fairly rapidly if exposed to the weather, covering them with shrink-tube will help prevent this but stops you pulling them apart. I think they are an untidy way of doing the job but are quick to put on if you have the ratchet tool and are readily available.
Pre-insulated spade connectors, butt connector and crimping tool. Note use of two crimps per wire.
https://www.bikechatforums.com/download.php?id=10637
EDIT: The female terminal shown here is only partially insulated, for a 'loose' joint you should use the type where the insulation covers all the exposed metal (I am getting short on them so I used a different type for the demonstration).
Non-insulated crimp terminals
These are what the manufacturer of your bike chose to use and are my recommendation for wiring on your bike. They are usually bullet type but spade and ring terminals are also available. A slightly different type are also available to slot into connector blocks and are attached in the same way.
Each terminal comes with a piece of silicone rubber insulation, remember to slip this over the wire before applying the terminal.. Again there are two crimps per terminal which should be applied using the correct crimping tool. This tool is different to the one for pre-insulated terminals in that it has a shaped die which curls each tag back on itself giving an extremely secure join. Again, one crimp for the end of the wire, the second for the insulation.
It is possible to apply solder to these terminals once crimped for extra security but the same applies as for soldered joints if one side is rigidly fixed. Once fixed the insulation slots into place over the top of the terminals. For added protection from corrosion, a dab of copper grease can be applied to the exposed metal of the terminals.
Non-insulated bullet connector with tool and insulation in place on the female terminal
https://www.bikechatforums.com/download.php?id=10635
Other types are available including:
Heat shrink pre-insulated where you heat the insulation after crimping to release glue that is contained within the insulation.
Pre-soldered butt connectors where you apply heat to the connector with the wires in place which releases a blob of solder into the joint whilst at the same time shrinking the insulation over the ends of the wire.
Hexagonal crimps are an old fashioned way of doing it and are a type of non-insulated terminal. The crimping tool for these is expensive.
Solder on terminals which have a 'cup' in place of the crimp which you fill with solder and insert the end of the tinned wire before it solidifies. These are quite fiddly to use and really need to be done on a bench.
Do not use 'scotchblock' Connectors, they damage the wire, often actually cutting a few strands and WILL fail by allowing corrosion to get inside the wire insulation. Screw-in 'chocolate bolck' terminals are for heavy duty mains wiring NOT vehicle wiring, they do not hold the insulation securely (or at all) and WILL break off. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| Guest |
 Guest Brolly Dolly
 Posted: 21:18 - 16 Jan 2005 Post subject: |
Nice one SW
It's worth pointing out, if you use bullet connectors, that the female (socket) connector should be used on the 'supply' side of the connection i.e. the end nearest the fuse. This is so that if the connection comes apart in use you don't have a bare bullet end floating about with volts on it. |
| Back to top |
| kasandrich |
 kasandrich Trackday Trickster
 Posted: 14:00 - 17 Jan 2005 Post subject: |
Excellent Article Stinkwheel,
As you have stated, crimps are best as long as they are properly done, and a properly fixed crimp will not come off easily, so once done give it a firm tug, to ensure the cable is properly crimped, it is better that it comes off in your hand now, than out on the road later.  ____________________ Richard
CBR1000FM |
| Back to top |
| Ninja |
 Ninja Caption Abuser
 Posted: 16:13 - 17 Jan 2005 Post subject: |
'two crimps' - ahaaaaaaa!  ____________________ James
4 wheels transport the Body ... 2 wheels transport the SOUL |
| Back to top |
There is a gap of 5 years, 60 days between these two posts... |
| smegballs |
 smegballs World Chat Champion
| Back to top |
| MarkJ |
 MarkJ World Chat Champion
 Posted: 09:37 - 18 Mar 2010 Post subject: |
Google says a wire nut. Could also try a large block connector or just a whacking great blob of solder  |
| Back to top |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 12:50 - 19 Mar 2010 Post subject: |
My way might work. Bodge bloody tastic.
Got a cheap fuel pump from a VFR 750 as was told they are the same model. They truly are near as damn, but the connector was different and I needed the bike the next day.
Cut the wires from the pump, cut the wires from the original pump (to get the original connector) and then whacked them in one of these...
https://www.newmartelecom.com/Electrical-Installation_Accessories/SPLASH-PROOF-JUNCTION-BOX.jpg
(NB: Can't find a picture of just them on their own, but the black bit in the middle of the box -anyone know their proper name?-, cut 2 wide)
And then used liquid metal to seal the holes water tight.
Still going strong  ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Back to top |
| MarkJ |
| Back to top |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Back to top |
| Kickstart |
 Kickstart The Oracle
| Back to top |
| chris-red |
 Posted: 15:11 - 19 Mar 2010 Post subject: |
Don't listen to Stinkwheel just do what I do and twist the 2 ends together and cover it in electrical tape  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Back to top |
| Blackwolf |
 Blackwolf Burgerfist
| Back to top |
| Gazdaman |
| Back to top |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 17:50 - 19 Mar 2010 Post subject: |
Also known as a "terminal block", or "terminal connector"
(such are the joys of spending summer breaks doing casual cash-in-hand jobs with my electrician father) ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| Back to top |
| lllN30lll |
 lllN30lll World Chat Champion
| Back to top |
There is a gap of 2 years, 273 days between these two posts... |
| Jafmandaddy |
 Jafmandaddy Derestricted Danger
| Back to top |
| D O G |
 D O G World Chat Champion
| Back to top |
| Asharin |
 Asharin World Chat Champion
| Back to top |
| Hobgoblin |
 Hobgoblin Trackday Trickster
| Back to top |
| anthony_r6 |
 anthony_r6 World Chat Champion
| Back to top |
| Charlie |
 Charlie World Chat Champion
| Back to top |
| Hobgoblin |
| Back to top |
| james1988 |
 james1988 World Chat Champion
| Back to top |
There is a gap of 1 year, 125 days between these two posts... |
| Bunny Lingus |
 Bunny Lingus Traffic Copper
 Posted: 01:15 - 23 Apr 2014 Post subject: |
Mods, you might want to move this somewhere more suitable. I did do a search before I posted this but couldn't find nowt.
Sorry for resurrecting this ol' lady but it is a great source, especially to retards like me who view wiring specifically & electronics in general as a black art. As Ash from Army Of Darkness says, my 'primitive intellect wouldn't understand alloys and compositions and things with... molecular structures.'
This is probably going to sound daft but I have an old CB125s engine & a CG125 frame & some wheels & other bits such as old wiring looms. What I want to build is the most minimal bare bones cafe style bike I can get through an MOT with no electrical gubbins or wiring at all except one pilot/headlight/full beam & a tail/brake light, so no battery.
Here are the questions. The CB lump is 6volt.
1. Am I right in thinking that the 6volt geny will run both lights without a battery?
2. Do I need a reg/rec or a relay?
3. Is a blue full beam indicator lamp, green neutral indicator lamp & speedo lamp necessary for the MOT test?
4. Are fenders necessary for the MOT test?
5. Do I need to bridge any of the wires from the geny to get the engine to run?
I think that's about it but if anyone can throw some tips my way I'll be eternally grateful. If I don't hear anything I'll re-post in the workshop. Thanks in advance fellas...  ____________________ Bunny Lingus & The Flipside Faggots |
| Back to top |
| Nexus Icon |
 Nexus Icon World Chat Champion
| Back to top |
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful? |
