| speedometer malfuncting on Hongdu 125 |
| Help will be greatly appriciate. |
0% |
[ 0 ] |
| thanks for the idea |
0% |
[ 0 ] |
| Total Votes : 0 |
| ramesh kotecha |
 ramesh kotecha L Plate Warrior
 Posted: 19:37 - 07 Feb 2005 Post subject: speedo cable malfuncting. anyone can help? |
I have Hongdou 125 bike. recently my speedometer stoped showing above 20MPH even when I know I am doing 40MPH. Any body has encounter similar problem. I do not want to dismantle anything unnecessary. |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 20:30 - 07 Feb 2005 Post subject: |
This is in the wrong section, but the problem is a far too familiar one with me at least. The speedo cable stopped showing above 45 on my Hongdou 125 after about 600 miles. 2000 miles later, and I've got a new cable, but it's at home and I'm not, so I've still not got around to replacing it.
The problem is that the cable is sticking. The speedo mechanically driven, by a spinning cable within an outer sheath. The problem is that at higher speeds, the spinning inner cable sticks to the outer sheath, slowing down and hence your indicated speed drops. Then, when it winds up enough to unstick it, it flies round and overcorrects itself as it is then going faster than the wheelspeed in order to catch up with itself. Hence the speedo will fluctuate and flap about, and not show any reading higher than a specific value where it sticks.
Eventually, given enough twisting, the cable will break and need replacing. Ideally, replace it before it breaks.
Which Hongdou have you got? If it's the same as the one in my profile, it is a direct clone (bar the engine and upgraded brakes+ electrics) of the Honda CM125. A speedo cable for that should fit, if the company you buy it from send the right one.
Oh, and (assuming that is the same as mine) if you could let me know if you ever manage to source replacement 12V15W bulbs, I'd be eternally grateful.  ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| bish777 |
 bish777 World Chat Champion
| Scotsman37 |
 Scotsman37 World Chat Champion
| mchaggis |
 Posted: 21:25 - 07 Feb 2005 Post subject: |
Aha! The one on that link looks remarkably similar to the one I already have, I wonder if it's the same fitting.. The scooter headlamp bulb CMC supplied my brother with when he went to look is 6V25W, which is the burnt out one in the picture, but it is exactly the same fitting. (attached, sorry for the dodgy picture quality but there's not much daylight around just now).
HEADLIGHT BULB
P26S
12 VOLT 15 Watts (BLB100)
https://www.beedspeed.com/bulb%20p26s.jpg
If it's the right one, you are a star!
That reminds me, the bulb in my speedo appears to have gone awol too. That should be straight forward to find a replacement for, once I can find the time to take the speedo to pieces to find it.
Thanks for that link.  ____________________ I must not be a troll...
Mmmm, Guinness
| Scotsman37 |
The last post was made 20 years, 361 days ago. Instead of replying here, would creating a new thread be more useful? |
