| overdog |
 overdog L Plate Warrior
 Posted: 15:40 - 13 Mar 2005 Post subject: Noisy Mito |
Just rebuilt a mates Mito after she left it standing for 2 years without even starting the thing-I know, I know!
Anyway-disconnected the coil and turned it over on the starter to get the oil pressure up before i fired it up.
There was a horrible clanking noise from the top end.It runs fine but theres a top end noise at tickover increasing with revs.If you spin the motor with the kill switch off the top end clank is still there.
Surely this isnt normal for a 2 stroke?
Im thinking rings-please tell me Im wrong! ____________________ Ooooh-thats gonna leave a scar! |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| overdog |
| cagiva gezzer |
| overdog |
| cagiva gezzer |
| simon1221 |
 simon1221 World Chat Champion
| overdog |
 Posted: 23:11 - 13 Mar 2005 Post subject: |
Powervalve does what its supposed to when you turn the ignition on.Noise is a rattling bang!If its been stood for 2 years whats the likihood fo a ring being seized and breaking when I started it?Or is the powervalve more likely(I hadnt even thought of that!)
It does sound like the piston is smacking something-I dont think its just slap.Bike has done 6000-not regularly serviced from what I can gather.
I dont want to condemn the wretched thing if it can be easily fixed but I was raised on inline fours and 2 strokes work by black magic as far as Im concerned-and it does sound fairly terminal.
Closest noise i can compare it to is a piston clattering a valve at the top of the stroke but obviously thats not the case here.
Rings catching the port edge?  ____________________ Ooooh-thats gonna leave a scar! |
| Frost |
 Frost World Chat Champion
 Posted: 06:40 - 14 Mar 2005 Post subject: |
Ring catching the port edge is very unlikely. Ring catching the powervavle sticking out of the port...very likely. I've had that one ahppen with 3 valves now
Check the spark plug. You probably put a new one it before fireing it up. If the plug is too long the cylinder might be hitting it...
2 Stroke singles are so easy to strip down it might be worth having a look inside, all it will cost you is a head gasket.
Check bolts too i was once VERY concerned about a loud engine noise which happend at engine speed. Turned out to be a loose powervalve cover  |
| Kickstart |
 Kickstart The Oracle
 Posted: 08:41 - 14 Mar 2005 Post subject: |
The Mito is a 2 stroke. It has no high pressure oil system and no oil pressure warning light. The light is just to indicate the level of the 2 stroke oil.
Most likely the piston is worn or the rings are siezed. Also the power valve on the Mito has an adjustable stop position. Get this wrong (or just take it out, clean it and reassemble without replacing the gasket so it is more compressed than it should be) and it can touch the piston when it gets hot. If it is run for a while in this condition the shaft for the power valve blade snaps and then the valve drops down.
The last post was made 21 years, 250 days ago. Instead of replying here, would creating a new thread be more useful? |
