| dandit |
 dandit Nearly there...
 Posted: 12:48 - 04 Mar 2005 Post subject: clutch upgrade (bandit 6 to bandit 12) |
ok I have had a brainwave can I put the bandit12 clutch in my bandit6 or can I upgrade mine to hydraulic????? somehow I fink I would prefer hydraulic clutch IDEAS/ADVICE please  ____________________ WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo |
| G |
 G The Voice of Reason
| Guest |
 Guest Brolly Dolly
 Posted: 13:10 - 04 Mar 2005 Post subject: |
You'd have to seriously mod the 600 sprocket cover - ally welding and then some machining - to accept the 1200 slave cylinder. Not worth the hassle IMO  |
| dandit |
 Posted: 13:13 - 04 Mar 2005 Post subject: |
I am thinking of putting the old gsxr 750 head on it and would just like to have a hydralic clutch aswell just an idea I had thats all as all my bikes I have had I have snapped clutch cables even though I lube and adjust regulary ____________________ WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo |
| Bendy |
 Bendy Mrs Sensible
| dandit |
 Posted: 13:24 - 04 Mar 2005 Post subject: |
| G |
| dandit |
 Posted: 14:18 - 04 Mar 2005 Post subject: |
| G |
 Posted: 14:27 - 04 Mar 2005 Post subject: |
No reason a clutch cable should go if it's checked regularly .
You could always get a braided steel outer for your clutch cable; would be a lot easier than modifying the bike to work with a hydraulic clutch.
Paying the insurance on the bandit 12 may well be cheaper than getting something like that made up for you. |
| Kickstart |
 Kickstart The Oracle
 Posted: 14:44 - 04 Mar 2005 Post subject: |
Think the Bandit 1200 clutch is based on the GSXR750 design but with hydraulic actuation (think the 750 is cable operated). Easiest thing to do would be to use a 750 clutch.
The 1200 clutch is not that strong, which is why mine has Barnett plates and springs in it (once the engine was played with it let go by about 6000rpm in every gear, even with brand new plates).
If the Bandit 600 clutch is actuated on the clutch cover then it would probably be a major amount of work as you would need to machine the crankcases to accept the actuating rod that goes through the gearbox, assuming that is possible.
Personally I far prefer hydraulic clutches to cable ones. Never had any real problems with hydralic ones, but had quite a few cables snap or just get too stiff to use smoothly.
| sickpup |
 sickpup Old Timer
| dandit |
 Posted: 20:50 - 04 Mar 2005 Post subject: |
it doesnt have to be a b12 but I'd realy like a hydraulic clutch as I have had a few hydraulics and never had problems with them but cable ones are an arse especily in winter when it gets caked up with salt and crap hmm hydraulic clutch is the way to go me thinks... keep the ideas comming folks I would like to bin the cable operated one its arse ____________________ WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo |
| G |
| dandit |
| sickpup |
 sickpup Old Timer
| dandit |
| sickpup |
 sickpup Old Timer
| dandit |
| Robby |
 Robby Dirty Old Man
| dandit |
| iCraig |
 iCraig World Chat Champion
| dandit |
| Kickstart |
 Posted: 19:18 - 09 Mar 2005 Post subject: |
If you are tempted with a 1200 Bandit then check the insurance. It is one group lower than a GSXR600, and people on here have got those insured for well under £1k having just passed their tests.
The noise is likely to be the valves rather than the bores. If the bores / pistons were worn enough to make a load of noise then the oil consumption would probably be hideous. The Bandit valves are meant to be regularly adjusted (from memory, every service).
Keith (also a fan of hydraulic clutches rather than cables) ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| sickpup |
 sickpup Old Timer
| dandit |
The last post was made 21 years, 216 days ago. Instead of replying here, would creating a new thread be more useful? |
