Brakes sticking
DarrenJ
PostPosted: 17:02 - 28 Mar 2005    Post subject: Brakes sticking Reply with quote
The front brakes on my bike were starting to rub so I took the front caliper off to inspect the pads, worn and in need of replacing but still a satisfying amount of pad left to last me at least a few weeks.
I put them back but when I spin the wheel the brakes don't seem to retract they're not seized as they go from being really tight when I apply the brakes to heavy rubbing when I remove them.
PostPosted: 18:11 - 28 Mar 2005    Post subject: Re: Brakes sticking Reply with quote
Copper grease on the moving parts; especially the pin holding the pads, may well help.
There is argument whether you should use copper grease or go to the extra effort to get rubber-grease for the pistons.
mr jamez
PostPosted: 18:21 - 28 Mar 2005    Post subject: Reply with quote
Remove the pads, pump the pistons out a bit and clean them up with brake fluid. And like above, lots of grease helps. If it is a sliding caliper remember to clean out the rubber boots and pack them with grease, that should sort it out.
DarrenJ
PostPosted: 19:18 - 28 Mar 2005    Post subject: Reply with quote
I gave them a clean but unfortuantly the piston came out and all the brake fluid pissed everywhere luckly no paint was lost other than some from a screwdriver head.
Is it as simple as just topping the fluid up again and leaving it overnight with the leaver zip tied in to bleed it?
simon1221
PostPosted: 19:20 - 28 Mar 2005    Post subject: Reply with quote
Bleeding isnt difficult, even I can do it and ive broken a fair few things in the past. Karma
The last post was made 21 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.84 - MySQL Queries: 14 - Page Size: 43.12 Kb
