derestricting nsr, how do I take the plastic tray off?
ayfy
PostPosted: 21:02 - 11 Apr 2005    Post subject: derestricting nsr, how do I take the plastic tray off? Reply with quote
I'm currently in the middle of derestricting my NSR and I'm following the steps provided on nsr125.com. I'm having trouble trying to remove the plastic tray holding the servo motor just above the engine.
It says on the website there's a bolt on the left and a plastic clip on the right. I've taken the bolt out, and I'm assuming where it says plastic clip on the right, it's referring to the bit that sticks out of the frame and into a hole on the tray as I cannot see any plastic clip as such. I've managed to get the tray of the bit sticking out of the frame but the tray still won't budge, it seems like something else is holding it down in the middle or towards the left front.
anyone got any ideas on how I get it off? how many bolts, clips are there that I need to remove?
actually looking at the instructions again, do you need to remove this part to get to the intake tract?
ProXimaCore
Dougal
PostPosted: 21:06 - 11 Apr 2005    Post subject: Reply with quote
I never actually got mine out. I had a hard time with mine too. I just loosened it off a bit enough to lift it slightly to get into what I needed. Bt of a tight squeeze though.
Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing Sad
fuzz
PostPosted: 21:42 - 11 Apr 2005    Post subject: Reply with quote
This is definately the trickiest part to remove I have come across. The only solution I found was to remove the electrics/pipes on the left and take out the screw. You should then be able to lift it sufficiently to pull up and out towards the left. On the right, it is held in only by two supports that fit into the frame. You may have to bend the tray slightly to get the supports out. Once they're out, turn the tray to the diagonal and lift it out.
On the guide, they say pivot the tray to get to the carb, but it's not impossible to remove it completely, and should give you more room to work.
The last post was made 21 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.89 - MySQL Queries: 14 - Page Size: 36.63 Kb
