Hairline crack
barrymc
PostPosted: 02:48 - 13 Apr 2005    Post subject: Hairline crack Reply with quote
Hi there,
I have just put a second hand ignition casing on my NC23, unfortunately I must have over-tightened it and cracked the casing, which is now leaking oil. Embarassed
I don't want to go to the hassle and expense of getting another and I am thinking of using steel filled epoxy putty, eg Devcon.
What I'd like to know is if anyone can has actually used this in a similar type of repair and whether it's effective or not.
Cheers,
zooooooooooooooooommmmmm!
PostPosted: 03:43 - 13 Apr 2005    Post subject: Reply with quote
I have seen dirty great holes (well up to 1/4") in crankcases repaired using lumiweld and JB-weld epoxy. These two brands seem to be the ones to go for.
Degrease thoroughly and open the crack out a bit into a v-shaped groove with a dremmel to give the epoxy a good surface area to key on to.
Assuming it is alloy, if your repair fails, you can always get someone to TIG weld it up for you.
If it is plastic, you could also try 'stitching' it with a soldering iron. Melt a series of 'hatchings' across the crack then smooth these along the length of the crack. Do the same on the other side. Make sure you get far enough past the 'point' of the crack to stop it spreading further.
If it doesn't work, you haven't lost anything by trying.
barrymc
PostPosted: 21:39 - 13 Apr 2005    Post subject: Reply with quote
Cheers for that Stinkwheel Thumbs Up
It'll be a couple of weeks before i get a chance to do anything with it as I'm working offshore but I appreciate the help.
I see from your profile your originally from Huntly, you might know my cousin Gordon McQueen (chef to trade). I don't know if he's still there as I haven't spoken to him since his dad's funeral a few years back.
Anyway, ta much
PostPosted: 05:59 - 14 Apr 2005    Post subject: Reply with quote
The name doesn't really ring a bell, but I haven't been back for any length of time in the last nine years.
The last post was made 21 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.95 - MySQL Queries: 14 - Page Size: 40.65 Kb
