Inside a cagiva engine-if you like that sot of stuff.>2mb
cagiva gezzer
PostPosted: 14:26 - 24 May 2005    Post subject: Inside a cagiva engine-if you like that sot of stuff.>2mb Reply with quote
Take one Cagiva Supercity 125....
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva1.jpg
Add a simultaneous big end / small end failure…..
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva2.JPG
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva3.JPG
Start the strip down...
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva4.JPG
Remove the flywheel/magneto. The worst part of the job, it pops off like a Exclamation . The Spanner is used as a brace to lock the flywheel so less hands are needed......
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva5.JPG
Put the remains to one side....
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva6.JPG
The heavy lump of the engine.....
https://www.bangor.ac.uk/~bsuc15/Cagiva/cagiva7.JPG
The stator plate....
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva8.JPG
The primary drive, clutch basket, intermediate gear, balancer shaft and oilpump/tacho drive....
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva9.JPG
The intermediate gears (right) and the balancer shaft (left) correctly aligned, as shown by the marks where the two gears meet….
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva10.JPG
The gear selector mechanism, the water pump gear, primary gearbox shaft (clutch basket removed) and the end of the secondary gearbox shaft (in a clockwise motion). Empty bearing seat in bottom left is for fitment of a kickstart.....
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva11.JPG
The inside of the engine/gearbox.....
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva12.JPG
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva13.JPG
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva14.JPG
https://www.bangor.ac.uk/~bsuc15/Cagiva/Cagiva15.JPG
Just got to send the crank and cylinder off now. Big up to Mito Mondo for shipping in parts SOO fast.
The pictures show why i love stroker engines soo much. They're so simple, yet powerful. I think deep-down i love it when it goes bang.....
If you're thinking about doing this to your own engine, it took me 7 hours to strip the bike and get as far as starting to split the crank cases, then another hour or so getting the crank out.
EDBANGER
PostPosted: 14:55 - 24 May 2005    Post subject: Reply with quote
I wish I knew how to do all that. It just looks scary as fook when you have no idea. Sad
J.K.R
PostPosted: 14:59 - 24 May 2005    Post subject: Reply with quote
My old wmx 250 didnt take too long to strip down which was handy after the ten or so attempts at getting the gearbox right after buying bearings and seals for all of the bottom end (needed them) and when i took the selectors out etc forgot where they went Brick Wall the rest of the engine wasnt too complicated
hope everything goes well Thumbs Up
www.oldskoolsuzuki.info
tatters
Exxon Valdez
PostPosted: 17:09 - 24 May 2005    Post subject: Reply with quote
your lucky the crankcases split Vertically and not horizontally like on a KR1S, pain in the ass getting the gear box back together.
if you can,t get hold of any yamabond for the crankcases, blue hycomer or three bond is as good.
The last post was made 21 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 14 - Page Size: 43.33 Kb
