Bike electrics, accessories, fuses and relay advice request
map
Mr Calendar
PostPosted: 16:09 - 01 Aug 2005    Post subject: Bike electrics, accessories, fuses and relay advice request Reply with quote
Planning to add some extra lights (front and back), those wrap on heated grips plus GPS power cable to the bike. For some reason having difficulty getting my head around vehicle electrics and I'm seeking some advice. Three little queries:
(1)
Plan A
This was to fit additional fuse box powered from battery by a relay from a switched source (i.e. no power unless bike turned on).
Then from the fuse box run power to the accessories via switches as required.
Plan B
From another friend who insists for me not to switch the power this way but to fit the fuse box AND individual relays and switches for each circuit.
Now Plan B requires me to get my head around a lot of other wires and square relay blocks to attach and squirrel away. I'm also not sure it's required. As an example the instructions for the heated grips just say take it straight off the battery (but I want it via the fuse box as then can't be accidentally left on). There are no other relays in the heated grip circuit.
So I'm left a little confused. Ideally I want to give myself an easy life so a simple solution (is that Plan A?) would be appreciated.
(2)
Could anyone also please let me know what specification of wire I should be using (I'm assuming max. 30A circuit).
(3)
As it's an old bike for touring I did fancy fitting 4 way flasher. This is a separate project as I'm thinking it'll need some piezo sounders. The circuit will be active direct from battery (so can be active if ignition circuit dead) so sounders required to put off anybody passing by 'accidentally' switching it on. Does this sound like a good plan?
Thanks in anticipation Thumbs Up
benc
PostPosted: 16:53 - 01 Aug 2005    Post subject: Reply with quote
I would go with plan a as there is a lot less to go wrong. as long as you get a suitable relay(that will take the current from all the lights ect.) it should be fine
PostPosted: 17:33 - 01 Aug 2005    Post subject: Reply with quote
Either will work fine providing you use thick enough wire to cope with the load. I would also fuse those things seperatley as you are talking about very different power demands. You will almost certainly need a relay for the grips, maybe not for the other lights (depending on draw) and probably not for the GPS.
So what I would do is run a big fat wire from the battery through a fused relay that is activated by an already existing switched supply (the rear brake switch or flasher relay is often a conveniant place for this.)
Use that to supply a mini fuse box then run your wiring up to the different accessories as required. As I said, you will probably need a relay for the grips as they would require a very heavy duty switch and wiring attaching to your handlebars otherwise.
Kind of like this (earths not shown for clarity):
map
Mr Calendar
PostPosted: 22:17 - 01 Aug 2005    Post subject: Reply with quote
stinkwheel wrote:
Either will work fine...
Thanks for the info.
That's just about how I'd sketched it out.
I'm ok with circuit diagrams but it all goes fuzzy when faced with a wiring loom Rolling Eyes Very Happy
Just one last point to confirm, if I used relays (as for the heated grips) I'd still have to run a feed (say fused 5A) to trigger the relay?
Thanks.
PostPosted: 01:06 - 02 Aug 2005    Post subject: Reply with quote
Yes, well spotted. The only reson to use a relay there is to avoid taking a high current up to the bars which would mean thick wires and a heavy duty switch. I suppose it all depends on how hefty a switch you get with the grips as to if this is necessary. The heavy wires will have to go up to the bars anyway to power the grips. The switch you get with them may well be good enough to take the full whack in which case you may as well just take the wires all the way up from the fuse.
I suppose thinking about it, relays would probably be more useful in the headlamp circuit then you can use the feed from the existing switches to trigger the relay, means you wouldn't need new switches. You can usually hide the relays in the headlamp shell.
As I said, there is usually a live feed that comes on with the ignition going into the back brake light switch which should be fine to trigger your 'main' relay. Some bikes also have a 'spare' live in the existing fusebox.
The last post was made 20 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 3.71 - MySQL Queries: 13 - Page Size: 49.07 Kb
