| Philious |
 Philious Brolly Dolly
| knockout_bar |
 knockout_bar Scooby Slapper
 Posted: 11:19 - 31 Aug 2005 Post subject: |
Do you know what oil is in the gearbox now? If so, put the same stuff in next time.
If you don't know, drain it as much as you can and fill it up using ENGINE OIL. NOT two stroke oil.
If you're going for a service, change the spark plug. Make sure the oil tank is topped off (this should be with 2 stroke oil). Check the chain tension and wheel alignment. Check the brakes. Oil the control cables (just a little bit down the end of the clutch and brake cables (only if your front brake is drum)). Put chain lube on the chain (all the way round). Check that everything is secure in place i.e. no rattling bolts, cracked plastic. Check all the electronics are working, and listen out for unusual sounds. ____________________ 125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee)  |
| Paracaine |
 Paracaine Nitrous Nuisance
| knockout_bar |
| Kickstart |
 Kickstart The Oracle
The last post was made 21 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
