Best way to de-coke a 4T without taking the head off
knockout_bar
PostPosted: 22:46 - 31 Aug 2005    Post subject: Best way to de-coke a 4T without taking the head off Reply with quote
Redex? I took the downpipe off today (getting the restricter out of it), and the port was completely black. So, I got the torch and took a closer look; the exhaust valve (what I could see of it) was completely black aswel. What's the best way to de-coke the engine? I don't want to take the head off because i'm no good with cams and valves.
125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee) Thumbs Up
Milo
PostPosted: 00:34 - 01 Sep 2005    Post subject: Reply with quote
A good warm up followed by a very good long thrashing once she's thoroughly warmed up.
Redex may well help the process and certainly can't hurt. Thumbs Up
EDIT - is she's not roadworthy then I've no idea. Not tinkered with 4-strokes before.
Shaft drives rule. Razz
VFR400UK
PostPosted: 00:54 - 01 Sep 2005    Post subject: Reply with quote
Squirt some red Ex up the exhaust port and leave it overnight.
mchaggis
PostPosted: 15:42 - 01 Sep 2005    Post subject: Reply with quote
Take the airbox off, set it at a high idle, and slowly dribble about 1/3 of a bottle of Redex or similar directly into the carburettor body. It worked a treat for me.
I must not be a troll...
Mmmm, Guinness
BlackSheep
PostPosted: 19:51 - 01 Sep 2005    Post subject: Reply with quote
Take the plugs out , pour 50 ml of redex into each cylinder , leave it for 30 mins , then place old rags over each plughole and wind the starter over a few times to blow the redex out , refit the plugs and start it up , it will smoke like a twat for a few mins then it's good to use , i've done this a few times and it works very well .
GSXR 1100 StreetFighter
mchaggis
PostPosted: 21:13 - 01 Sep 2005    Post subject: Reply with quote
Blacksheep, do you normally put the Redex into a hot engine?
Mmmm, Guinness
BlackSheep
PostPosted: 12:52 - 02 Sep 2005    Post subject: Reply with quote
No i usually do it from cold , if you put it in hot it would probably just boil off , there used to be instructions how to do it on the redex bottles,
don't know if there still are , i've not had to do it for a while.
fuzz
PostPosted: 14:23 - 02 Sep 2005    Post subject: Reply with quote
There are instructions for the three methods of using it on the bottle. Follow as per.
The last post was made 20 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.38 - MySQL Queries: 14 - Page Size: 55.75 Kb
