How to look after the bike during winter
froggy128
PostPosted: 16:46 - 23 Sep 2005    Post subject: How to look after the bike during winter Reply with quote
whats the best way to look after bikes during winter
ive got some scottoiler spray.
What can i spray on the paintwork to protect it?
eli_74
PostPosted: 17:16 - 23 Sep 2005    Post subject: Reply with quote
Where dya get the scottoiler spray from? i'm after some...
Well, I'm sure I'd feel much worse if I weren't under such heavy sedation.
bn125 Eliminator / En400 Vulcan / XV250 Virago
froggy128
PostPosted: 17:20 - 23 Sep 2005    Post subject: Reply with quote
you can get it from cmc Thumbs Up
dodsi
Dirty Carny
PostPosted: 17:22 - 23 Sep 2005    Post subject: Reply with quote
www.scottoiler.co.uk
£30 with free shipping for 5 litres, cheaper than shop prices.
wax polish your paint up, thats the best stuff to use, wax the frame etc aswell. stops shit sticking so well.
craigs23
Mr Muscle
PostPosted: 18:27 - 23 Sep 2005    Post subject: Reply with quote
There's a similar thread in the New Biker's Section (or is it the Workshop Section?)
kb-zxr
PostPosted: 20:10 - 23 Sep 2005    Post subject: Re: How to look after the bike during winter Reply with quote
Water and soap when its dirty Razz
The best way to look after it is regulary clean it, and if possible always get the salt off after every ride, as it goes all furry, I think it can get quite bad on aluminium too. Fur is especially bad near wheels, calipers etc
Kurt
flat spot
PostPosted: 22:17 - 23 Sep 2005    Post subject: Reply with quote
Easy Peasy.........
https://img.photobucket.com/albums/v220/flattyman/bigbag1.jpg
......put it in a big bag and use the car. Wink
eli_74
PostPosted: 22:22 - 23 Sep 2005    Post subject: Reply with quote
Ta duck Thumbs Up Another reason for a drool around CMC Wink
dodsi
Dirty Carny
A bike is for life not just for summer.
dransy
PostPosted: 22:27 - 23 Sep 2005    Post subject: Reply with quote
You stole my sig bitch Laughing
dransy
well my old one Embarassed
dodsi
Dirty Carny
PostPosted: 22:28 - 23 Sep 2005    Post subject: Reply with quote
Yer what dick ed' (said in chav voice)
extreme3d
PostPosted: 23:00 - 23 Sep 2005    Post subject: Reply with quote
Lots of water, and I mean lots - it's ironic but the best way to stop corrosion is with lots of water so use a hose. Use car shampoo such as triplewax which has wax in it to wash the bike with. This will leave a film of wax over the paint, engine, frame etc. If you ride everyday YOU NEED TO DO THIS EVERY DAY PERIOD. If you don't it will rot plain and simple REGARDLESS of make (Yes even Honda).
https://img.photobucket.com/albums/v171/dodsi2000/771016.jpg
Once a week use fairly liquid. I don't care what people say about it being to harsh - bull sh*t. We are not talking about using it neat or in a pressure washer - just a squirt in a bucket of hot water and a sponge. Let the suds to the work by squeezing the sponge over difficult to reach areas so soap suds pour down into it. You will soon have the bike degreased/desalted including if you wish all the chain oil of the rear wheel and sprocket. (fairly liquid works wonders for stripping chain oil - *read below before you all jump on me for this*) Next and this is crucial - use car shampoo again, as yes the fairy liquid will strip off all wax from the paint.
Get a towel (i have a couple ragged ones for bike/car use only) and first dry the exhaust cans, downpipes and engine casings (to prevent spot marking). Then turn on the engine and let it idle whilst you dry the rest of the bike. The trick is to let the engine's heat dry the INSIDE of the bike. This is important as the bike will not dry off overnight in the garage during winter. It also gets water out of the HT leads etc.
Once the bike is dry then the paint will be protected and you are good to go next day. Once a weekend when you have more time then yes you can polish the paint work to make it gleam but there is little point as come monday you will just wash all the polish off again!!! Polish is more for summer when you need only wash once a week and need to protect the paint during the gap.
This may seem a lot, but once you get the hang of washing it need only take 5 minutes.
Now as for removing chain oil from the sprockets/wheel/chain. I find fairy liquid removes this muck in seconds as its an active degreaser. But you MUST oil the chain again after or it will rust. The best way for winter riding is to fit a scottoiler as the oil is water based and normal car shampoo will remove it no problem. The wax in it will provent rusting.
Finally as you have discovered spray the bike with Scottoilers FS365. This contains salt inhibitors and will neutralise and prevent the salt corroding the metal. It has one downside and that is dirt will stick to the oil making the bike look grubby. But as it's water based as soon as you hit it with the hose it all wash's off.
https://img.photobucket.com/albums/v171/dodsi2000/so_0040_45_2300_detail.jpg
There is no need to spray the whole bike as you will soon use it all up if you do. I concentrate on the following areas:
Front and Underside of the engine.
Exhaust Collector Box (where downpipes join together)
Rear shock.
Fork lowers - Use a paper towel soaked in the spray to avoid disks.
Radiator and/or oil cooler
Bottom of Yokes
Foot Pegs
It is also a good idea once a week to squirt some WD40 into all the handlebar switches as all this washing can mean water will start to enter them.
Hope this helps and are you coming on the ride out tommrrow froggy?
AcIdBuRnZ
PostPosted: 02:40 - 24 Sep 2005    Post subject: Reply with quote
Even coated aluminium? Wink
Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..."
mr.z
PostPosted: 03:22 - 24 Sep 2005    Post subject: Reply with quote
The easy lazy way...
Give your bike a good going over every two/three weeks, propper through clean with what you'd normaly use...
(when its dry) Then anything shiney, get wd40, spray away, exhaust (will stink + smoke a little when you start up again, just dont sit breathing the fumes!)
Plastics, dunno, you can get some sort of faring wax stuff, but its hardly difficult to wipe them down + they aren't going to rot off like chrome anyway...
Make sure everwhere that should have grease on (springs e.t.c.) has, then get on yer gloves and get a load on the underside of the swingarm and any particuarly exposed parts (get a rear hugger for your monoshock if this applys to your bike!)
Come summer you can just clean all the gunk off, it will look like crap through winter, the wd looses any shine you had got, the gunk will collect dirt (make sure to replace gunk reguarly) but when spring has sprung all your shiney bits will still be Smile
(been doing this for the past couple of years and its worked great up to now)
*Tesco sell packs of 3 toothbrushes, very very cheap, worth geting for chains and other smaller fiddleyer bits Thumbs Up
Teaman
PostPosted: 19:25 - 24 Sep 2005    Post subject: Reply with quote
dont use washing up liquid to wash your bike though,, it contains loads of salt
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
extreme3d
PostPosted: 20:45 - 25 Sep 2005    Post subject: Reply with quote
As i wrote, rinse the bike again with car shampoo after. Also just how much salt is two drops of fairy liquid per bucket of water going to contain??
mr.z
PostPosted: 20:51 - 25 Sep 2005    Post subject: Reply with quote
Too much
Its designed to be used on ceramics that are difficult to scratch, like a mild liquid sandpaper... it will mess up visors (and so plastics) slowly but the effect is very noticeable
Propper cleaner isn't expensive, autoglym motorcycle cleaner is quite good (and can be used on anything)
extreme3d
PostPosted: 21:48 - 25 Sep 2005    Post subject: Reply with quote
Well i've seen many a 'shiny' bike but when you actually get close......
palmer
Fiddled Kiddy
PostPosted: 21:50 - 25 Sep 2005    Post subject: Reply with quote
cover it in wd40...
extreme3d
PostPosted: 22:09 - 25 Sep 2005    Post subject: Reply with quote
If you prefer the engine gleaming do not use WD40 on it. It will perish rubber hoses/o-rings and burn onto the downpipes.
bish777
PostPosted: 22:22 - 25 Sep 2005    Post subject: Reply with quote
Hose your bike off once a week. Be careful not to get water into airboxes etc. Im especially cautious due to having pods fitted-i put a plastic bag over them. If you get water in your pipes run the motor up after to blow/steam it all out.
Ensure cables etc are GREASED. WD40 is good only for free'ing up stick mechanisms and getting out water. Get proper grease for everything else.
Paintwork and chrome etc can be protected with good ol mr sheen.
GSXR1100J
The last post was made 20 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 116.63 Kb
