help me deristrict my nsr 125 rk
nsr_rk_boy
PostPosted: 14:27 - 11 Oct 2005    Post subject: help me deristrict my nsr 125 rk Reply with quote
can any of u biker dogs help me deristrict my nsr125rk i have drilled the restrictor out in the exhaust and done the restrictor on the carb but the bike still only does 70 on a straight can any1 help me get it 2 go faster ???????
johnr
PostPosted: 16:50 - 11 Oct 2005    Post subject: de restrriction Reply with quote
i think its restricted electronically, i take it youve passed your test then? Question
in sidecars, no one can heaar you scream
stevo as b4
PostPosted: 17:16 - 11 Oct 2005    Post subject: Reply with quote
The pre 94 NSR's are supposed to be far harder to de-restrict than the post 94 u.k. bikes, is yours an official u.k bike or an import? as you can get RK's as either.
There are a few simple things you can check for like making sure that the throttle slide is not restricted, or that there are restrictions before the carb, etc.
If you cannot find out specifically how its restricted, then it would be good idea to have some dyno time, and then you can see what power it's making and where in the rev range it produces it. This along with AFR monitoring could help pinpoint the restriction, or allow you to try things out and see what effect they have, for example disconnecting the power valve motor and running the bike with the valve adjusted manually fully in each direction, etc.
nsr_rk_boy
PostPosted: 22:43 - 11 Oct 2005    Post subject: Reply with quote
yeah its a 94 (L plate) 2day i noticed that when i was going down hill in sixth gear it would not rev any higher than 9k but it redlines in every other gear???
how r they restricted on the throttle side because when i twisted the throttle as hard as i can in sixth (nearly braking it off) it revs bout 500 rpm more .....
the power valve is fully open (i think) becasue both the cables r loose but when i followed them up 2 the servo under the tank i noticed that the servo had been taken apart by the person who owned the bike b4 me and there was a cog bit missing inside ........
The last post was made 21 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.02 - MySQL Queries: 14 - Page Size: 39.06 Kb
