bike noise - hear the amazing flushing bike!
gamerboy
PostPosted: 23:17 - 03 Nov 2005    Post subject: bike noise - hear the amazing flushing bike! Reply with quote
this is the noise my bike is making help plzzzzz
PostPosted: 00:10 - 04 Nov 2005    Post subject: Reply with quote
Sounds like the starter is not engaging.
Not sure on the NSR, but on some 125s the starter uses a fairly crude weighted gear that flys out and engages on the flywheel. Sometimes they stick so the starter spins without engaging.
gamerboy
PostPosted: 00:16 - 04 Nov 2005    Post subject: Reply with quote
so wot do i do ?
romperstomper...
PostPosted: 01:45 - 04 Nov 2005    Post subject: Reply with quote
get a new starter motor !
Yeah I know !
Kram
PostPosted: 14:46 - 04 Nov 2005    Post subject: Reply with quote
starter clutch? chopped some teeth of a gear?
try bumping the engine over a few cycles. then press the starter, does it turn the engine over?
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
jonnay
PostPosted: 12:42 - 08 Nov 2005    Post subject: Reply with quote
Your battery is flat, the motor isn't turning quickly enough to flick the gear right out. Mine does it if I try to start it with high beam on, I turn the lights off and it's just go enough juice to start it.
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
LUXY DJ
PostPosted: 13:21 - 08 Nov 2005    Post subject: Reply with quote
yeah id charge battery 1st to see if its that as thats a simple thing to do to elimenate
then starter motor also do they have the bendix gear in them? like a ped were the starter motor pushes it out for it too engage the crank?
if so then i know of peds bendix gears that go
GSXR750
mirax
PostPosted: 19:59 - 08 Nov 2005    Post subject: Reply with quote
my rs125 done that and i found that the brushes needed replacing in the starter motor as that sounds like the 2 contacts are grinding
jonnay
PostPosted: 21:43 - 08 Nov 2005    Post subject: Reply with quote
Mine does it every time I leave the lights on and partially drain the battery - seriously, before you take anything apart, charge the battery, I'm sure it'll work. It's just not spinning fast enough to throw out the little cog which engages with the motor, and when it does, it turns very slowly because of the low voltage.
Bump it and rev it a little to put a surface charge on the battery, then try, that should give it just enough power to start properly...
Jon
Andrewc2oo5zx...
PostPosted: 23:06 - 11 Nov 2005    Post subject: Reply with quote
thats a battery problem
zxr's and cbr's
SUNDERLAND AFC
gamerboy
PostPosted: 23:29 - 11 Nov 2005    Post subject: Reply with quote
well i charged the battery now it make a normal sound but still wnt start
AzA
PostPosted: 21:48 - 12 Nov 2005    Post subject: Reply with quote
My RS125 did that when the battery was dead, and it wouldnt turn over.
When the battery was charged the engine was turning over but it still wouldnt start, as they try to start the engine it sends some petrol to the carb i think (quote me if im wrong) but i got a new spark plug as mine was totally buggered and it worked first time afterwards.
trying to use electric start when battery dead didnt help the spark plug in my case.
Sorry if i confuse you with this post my english is terrible.
Ride Safe
Currently riding a 2000 RS125, ( I have a bike at last Very Happy)
https://www.bikepics.com/members/bcfaza/
Ride Safe
True Blue
PostPosted: 10:06 - 13 Nov 2005    Post subject: Reply with quote
Sounds to me as if the starter motor is jamming.
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
The last post was made 20 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 79.75 Kb
