Suzi GP100
Mongrel
PostPosted: 20:58 - 06 Nov 2005    Post subject: Suzi GP100 Reply with quote
I am sure that this will only be the first of many posts on this subject, I've just picked up and aged GP100 for one of my lads, very cheap so not complaining, but the indicators don't work.
I'm not an electrics numpty, in as much that if you can point me in the right direction I''ll find and fix the problem, I have a multimeter and know how to use it and have fixed plenty of cars, 12 year old bikes with no manual is not my thing though.
Ideas please, I thank you.
Paul.
PostPosted: 23:31 - 06 Nov 2005    Post subject: Reply with quote
I'll start off by saying I don't know that bike exactly but they are much of a muchness. If I am being vague, it is because i don't know the exact details.
The wiring is very simple but prone to interference from the previous 15 or so 17 year old owners.
Ok. Does the brake light work with the engine off? If not, the battery could be flat. You could always test it with your meter, if there is at least 6v in it, it should be enough for the moment anyway. The frame is a negative earth.
First the obvious. Bulbs intact? Bulb holders rusty?
Next I would check the indicators themselves are working. Bad earths are common on bikes so check they are working. Easiest way is to connect a flying lead from the battery positive and touch it to the terminal of the wire going into each indicator in turn. If there are two, it is the coloured wire you want, not the white on black (which is the colour suzuki use for earth, although some just earth directly to the frame without a wire). If they don't all light up, deal with this first.
Next I would suspect the flasher relay, which is a metal cylinder about 1" in diameter usually located somewhere near the battery or under the tank (sometimes under a side panel, they are occasionally plastic and rectangular). There are two spade terminals on it usually labelled L and B. If there is power going into one of these with the flashers switched 'on' and it doesn't click, this is probably your problem (assuming the flashers themselves are working). You can buy a pattern 6V two pin flasher relay for about £3.50, they are not generally brand specific so eg. a honda one would do fine. These commonly fail, I have a pile of dead flasher relays in my workshop.
Failing that you are probably looking at a wiring fault, the colours carry through from the flasher relay and most of the wiring is in a big birds-nest inside the headlamp shell. Check for the usual broken/worn/disconnected wires. View any PVC tape with extreme suspicion as there was none in there when it came out of the factory!
The switch could also be faulty but this is unlikely.
Someone else with a wiring diagram may be able to give you more details.
satans_BIG_helper
PostPosted: 23:37 - 06 Nov 2005    Post subject: Reply with quote
runs to look in cupboard for his old GP100 manual
check the relay mine was shite i got one off a RXS100 or something like that which was miles better, and none of the lights really worked with the engine off cos 6v electrics suck ass.... i will see if i have the manual in my cupboard still i may even have some spares knocking about yours if u pay postage (including manual)
I will have a look n get back to u if u want
Mongrel
PostPosted: 22:13 - 07 Nov 2005    Post subject: Reply with quote
Errr, 6 volt electrics?
I did not know you got such a thing!
Are they definitely 6v on this bike, and if so, how intelligent is an Optimate charger Shocked , ooops.
The relay is full of water Laughing , probably not helping, will it be ok dried out or is it now FUBAR?
Thanks, Paul.
satans_BIG_helper
PostPosted: 23:50 - 07 Nov 2005    Post subject: Reply with quote
The GP is deffo 6volt electrics as i had to hunt around like a eediot to get hold of 6V bulbs for the mini indies i put on...
get a different relay m8 Smile most 6v relays will work for cheapness Smile
satans_BIG_helper
PostPosted: 23:52 - 07 Nov 2005    Post subject: Reply with quote
whereabouts in the country r u m8 ? as if ur near me i cud pop over n give a hand if its not too far Smile
PostPosted: 01:04 - 08 Nov 2005    Post subject: Reply with quote
You bet your ass. The headlamp runs on single phase AC direct from the alternator too.
I can see you are in for a treat Smile
satans_BIG_helper
PostPosted: 09:42 - 08 Nov 2005    Post subject: Reply with quote
and if its the standard bulb a candle in the wind is more powerfull Laughing
Mongrel
PostPosted: 21:23 - 08 Nov 2005    Post subject: Reply with quote
This is sounding more complicated than my Thundercat!!!!
...and I can't believe that a tin pot ikkle sh*tter like this can be more trouble than an IL4 600 Laughing
Christ, you just wind the rubber band up a bit more don't you?
You're right though, I think a workshop manual may be a good investment!
Satans Big Helper...if you have an old manual 'in the cupboard' or any other gems, let me know please.
Oh and we're in Brighton is the answer to your other question, Paul.
satans_BIG_helper
PostPosted: 22:01 - 08 Nov 2005    Post subject: Reply with quote
NO chance i can visit lol im in the lake district Sad i will have a root about i know i have some engine casings or side covers at least a stator plate, Ummmm some other random bits lol will take a piccy of the bits n list wot i got n look into the manual for ya Smile
Mongrel
PostPosted: 19:57 - 09 Nov 2005    Post subject: Reply with quote
Awww come on, it'd be a lovely ride out for you Laughing , 8 hours(ish) each way, sticking to the speed limit of course Mr. Green
If you can have a root around it'd be appreciated, p&p is no problem of course, just let me know.Thanks,
Paul.
Mongrel
PostPosted: 17:28 - 12 Nov 2005    Post subject: Reply with quote
Don't worry about the Haynes, got one now thanks, Paul.
The last post was made 21 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 74.29 Kb
