Fitted driveing lamps..
mr.z
PostPosted: 02:34 - 02 Dec 2005    Post subject: Fitted driveing lamps.. Reply with quote
https://img232.imageshack.us/img232/8285/dscf00024pz.th.gifhttps://img232.imageshack.us/img232/3743/dscf00054vz.th.gifhttps://img232.imageshack.us/img232/800/dscf00099aw.th.gif
Not exactly the prettyest things but oooooh do they work, they throw out 3/4 times more light than my current high beam, i'm really impressed Thumbs Up
They cost £15, ring "roadrunner" driveing lamps, took an hour or two to fit, mostly drilling the faring and trying to line them up (still wonky) they are wired right off the main beam, seeing as that the only time i could use them without flash frying oncoming drivers eyes
Gonna get some round fogs too and then move these elsewhere (the indicators would have been blocked if i'd put them where i wanted to originaly) might tidy up the wiring then too Razz
haGGard
PostPosted: 02:41 - 02 Dec 2005    Post subject: Reply with quote
I was wondering who knicked my old Ford Fiesta fog lights last week Wink Razz
Bet they dazzle a few people?
chaff mans random tingz on loot Razz
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen
mr.z
PostPosted: 03:08 - 02 Dec 2005    Post subject: Reply with quote
They are wired to come on with the high beam, so turn them off when other drivers are heading at me (unless they are one of these nobs who drive with high beam on everywhere then give them a couple of reminders Twisted Evil )
Had fogs on my previous bike wired up the same way, they were good but these are even better, fogs are good for lighting up the side of the road and aimed down shouldn't dazzle drivers too much (no more than other cars dipped beam)
You can get diddly driveing lamps but they cost £100 and aren't any better, so feck it, big meaty lights it is Thumbs Up
McGee
O RLY?
PostPosted: 07:34 - 02 Dec 2005    Post subject: Reply with quote
Different Thinking
Its pronounced Jixxer!
map
Mr Calendar
PostPosted: 10:41 - 02 Dec 2005    Post subject: Re: Fitted driveing lamps.. Reply with quote
mr.z wrote:
... Gonna get some round fogs too and then move these elsewhere...Razz
If fitting (rear) fogs then it/they must:
a) have an illuminated switch or separate tell-tale bulb to warn the operator that the fogs are in operation,
b) be mounted a minimum distance of 100mm from the brake lights, and
c) be no lower than 250mm and no higher than 1000mm from ground level.
In legal terms:
Schedule 11, Part 2 of the Road Vehicles
Lighting Regulations 1989 wrote:
Any vehicle not covered by sub-paragraph (B) - namely 'An agricultural vehicle, engineering plant and a
motor tractor'. If only one foglight's fitted it must be 'On the centre-line or off-side
of the vehicle (disregarding any sidecar forming part of a motor bicycle combination)'
I'd have to look at the regs for front ones (they're not normally found on bikes Confused Shocked).
I've a pair of the Ring Micro Cruise Lites (see here or check eBay) waiting to be fitted. I'm fitting for 2 reasons:
Arrow Increased visibility during the day. Will be using instead of dipped beam. The unusual configuration/pattern (2 lights close together) should make drivers look twice (that's the theory).
Arrow Increased lumination at night. I find this time of year on roads that I know I'm taking some corners like a 20p piece. One of the drawbacks of living in the sticks and country lanes I suppose.
Let us know when you've got your full setup.
HTH Thumbs Up
mr.z
PostPosted: 19:17 - 02 Dec 2005    Post subject: Reply with quote
Thanks for that, bizzarely i was looking at the ring microlights, they'd fit nicely anywhere too, kind of like the round fogs too though..
Got a switch and a pile of wiring bits and bobs ready to fit them, will have them to switch on with the low beam as its seeming very underpowered now
Just tryed them out... one is totaly off aim (because ive still not finished off one mounting propperly) but lights up the kerb nicely Laughing
If anyone is used to crap old lights these really are worth thinking about! its like haveing CAR headlights, they are as brights as the parents mk3 fiesta!
all in all very much the £15 (£5 of electrical bits maybe if you dont allready have them) and the time fiting Thumbs Up
riichy
PostPosted: 19:53 - 02 Dec 2005    Post subject: Reply with quote
i dont fancy meeting you head on !! Wink Mr. Green Thumbs Up
.......... PLOD ............ zx636 2004
Lee_367
PostPosted: 22:54 - 02 Dec 2005    Post subject: Reply with quote
Don't they thrash the battery and charging system?
I've seen them on bikes before, they do help you get noticed. Smile
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
Dom
PostPosted: 23:41 - 02 Dec 2005    Post subject: Reply with quote
Fifteen quid well spent. Thumbs Up
Photos and that
mr.z
PostPosted: 00:26 - 03 Dec 2005    Post subject: Reply with quote
Unfortunately they have to go off when things are comeing my way, (unless comebody pisses me off) they wont be blinding anyone..
As for the power, had a pair of fogs @ 55watts each on my first cx (with heated grips on at the same time) and this cx puts out more power, ran the fogs for a year with no problems sp am sure these will be totaly fine (provided they're not on with the engine off or useing them all the time)
Tbh i doubt PIAA lights are allot better at (sometimes) three times the price, and even if they are these defenately doing the job Thumbs Up
Glad i didn't shell £200 out on HID xenon lights now Shocked
haGGard
PostPosted: 01:23 - 03 Dec 2005    Post subject: Reply with quote
Will they pass an MOT though?
AcIdBuRnZ
PostPosted: 02:09 - 03 Dec 2005    Post subject: Reply with quote
Not exactly a hardship to remove them for MOT day though is it? Smile
Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..."
haGGard
PostPosted: 03:09 - 03 Dec 2005    Post subject: Reply with quote
Tut Tut
AcIdBuRnZ
PostPosted: 04:06 - 03 Dec 2005    Post subject: Reply with quote
Oh come on! How many of us have illegal race cans/small number plates etc? (just the race system for me - all else 100% legal Thumbs Up)
At least these have a purpose - to help you see better! Laughing
mr.z
PostPosted: 14:00 - 03 Dec 2005    Post subject: Reply with quote
Actually they will Razz
Provided they come on with a tel tale warning light (the high beam) they are perfectly legal, same as i had my first cx fogs set up and it pass its mot with not even a mention...
AcIdBuRnZ
PostPosted: 14:45 - 03 Dec 2005    Post subject: Reply with quote
Suppose. You can fir them to a car so what is really different fitting them to a bike?
They are serving the same purpose.
mr.z
PostPosted: 14:58 - 03 Dec 2005    Post subject: Reply with quote
UK REQUIREMENTS
When fiting a pair of driveing lamps you should follow the following legal requirements:
Driveing lamps should be positioned symetrically; the same hight and distance from the sides of the vehicle.
Lenses can be clear or yellow.
Driveing lamps can be used only with the main beam and should be extinguished when headlights are dipped.
There are no requirements for the positioning of driveing lamps, but you should not dazzle any other road user.
So there ye go Wink[/quote]
loply
PostPosted: 15:57 - 04 Dec 2005    Post subject: Reply with quote
I have to say, that bike is seriously ugly. But it looks functional, so thats worth something.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Visitor Q
$25 whore
PostPosted: 17:26 - 05 Dec 2005    Post subject: Reply with quote
Might fit some to the smod, purely to fuck off the first cunt who doesnt dip. Not that im into night riding up in wales Shocked But im hardly gonna trounce the CBR's lines with them now am i...
My mate james has some crazy gas lamp things on his dakar GS. There when he bought them. Ones white, ones bluey When they heat up abit, retinas burn. And thats during the day. At night...
mr.z
PostPosted: 13:07 - 06 Dec 2005    Post subject: Reply with quote
Yikes! sounds a bit mad! never heared of that? surely they done actually run off gas Shocked Laughing
Have had chance to use them a bit, its made night rideing allot safer, to the point i can go allot quicker, roads i'd be pottering at 40 i'm at 60 as i can can see waaaaay ahead Thumbs Up
Visitor Q
$25 whore
PostPosted: 20:08 - 06 Dec 2005    Post subject: Reply with quote
Fuck knows boyo.
But they are spotlight bright.
The last post was made 20 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 124.46 Kb
