| aprillia_16 |
 aprillia_16 L Plate Warrior
| Davo |
 Davo Davo To The Rescue!
| mr.z |
 mr.z World Chat Champion
 Posted: 19:01 - 03 Dec 2005 Post subject: |
Is it standard?
Has it been derestricted?
Have the carbs been fiddled with?
Is the airbox/carb connectio tight/not leaking (air leak will cause lean runing which will make it run like shite + not do much good for the plugs) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Cillit-BANG |
 Cillit-BANG World Chat Champion
 Posted: 21:47 - 03 Dec 2005 Post subject: |
| Mongrel |
 Mongrel Scooby Slapper
| mr.z |
 Posted: 00:23 - 04 Dec 2005 Post subject: |
I'm not sure but it could also be ignition timeing being a bit "hot"
Either way soemthing is VERY wrong if its only 2 days old!
Try the standard filter, if its letting more air through it will be runing lean..
Now i think of it the plug has to be the specific one reccomended in the manual, if the plug tempreture is too low then the plug will get murdered, if too low the spark wont be hot enough...
IF its only been doing it since plug changes than thats probably it ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Guest |
 Guest Brolly Dolly
 Posted: 08:20 - 04 Dec 2005 Post subject: |
| Mongrel |
The last post was made 20 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
