Bike wont start
bikefreedom
PostPosted: 21:31 - 14 Dec 2005    Post subject: Bike wont start Reply with quote
I have a 1997 bandit 600. The problem is that i am unable to start the bike. I think it has something to do with the cold weather. Any suggestion.
Dragonfly
PostPosted: 21:36 - 14 Dec 2005    Post subject: Reply with quote
does the bike try to go at all or is it dead? it could be electrical or check that your chokes work.
All the breast.
Muzza on Binge:
X-man
PostPosted: 21:41 - 14 Dec 2005    Post subject: Reply with quote
bandits are prone to carb icing
bikefreedom
PostPosted: 21:42 - 14 Dec 2005    Post subject: Reply with quote
battery is new, changed it feb05. choke works
bikefreedom
PostPosted: 21:43 - 14 Dec 2005    Post subject: Reply with quote
what do you recommend
Dragonfly
PostPosted: 22:07 - 14 Dec 2005    Post subject: Reply with quote
check your spark plugs or check to see colour of spark. white spark is good. check your carbs are not dirty, making sure that bike is getting petrol. also does the engine turn over? if all else fails get it to the doc. Thumbs Up
All the breast.
Muzza on Binge:
cathawhitt
PostPosted: 23:51 - 14 Dec 2005    Post subject: Reply with quote
I was told that for carg icing PRO FST works a treat!!!! Hope this helps!!! Are the connections to your battery secure (I know that sounds like a silly question but worth checking)
bikefreedom
PostPosted: 00:25 - 15 Dec 2005    Post subject: Reply with quote
i had a full bike service in feb 05. New plug, new battery, new filters the whole shooting match. Engine was checked as well as valves.
Knowlsey
PostPosted: 00:27 - 15 Dec 2005    Post subject: Reply with quote
have you tried a bump start yet
gimpy limp
PostPosted: 00:50 - 15 Dec 2005    Post subject: Reply with quote
my bike unless their is maximum charge in the battery or from a booster pack connected to the battery sometimes wont start in the cold even if the starter is turning the motor at a nice speed. Starts in half a second with a ful battery maybe try that either bump starting it (3rd gear let the clutch out at a steady slow run) or get a booster pack on it.
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
Psychonaut
PostPosted: 12:25 - 15 Dec 2005    Post subject: Reply with quote
Thought my electrics had gone the other day, turns out I'd stopped in a hurry and left teh bike in gear. Came back, turned the key and nothing (cos the side stand was down) Point being, have you checked the side stand switch, is it working, maybe a spray with WD40
Vin
PostPosted: 12:35 - 15 Dec 2005    Post subject: Reply with quote
Kill switch?
Bezzer
PostPosted: 12:47 - 15 Dec 2005    Post subject: Reply with quote
Forget carb icing, you won't get that when you first try to start it up. You've got to check whether you're getting a spark and fuel, then take it from there, there's too many things it could be to guess without more information as regards spark and fuel.
gimpy limp
PostPosted: 15:24 - 15 Dec 2005    Post subject: Reply with quote
oops ignore
Barney
PostPosted: 17:00 - 15 Dec 2005    Post subject: Reply with quote
Im sure you do already, but full choke with no throttle starts my bike everytime. It used to struggle starting up in the cold but now its fine.
CG125|CB400SF|CBR600FX|Triumph Daytona T595|CBR929RR
The last post was made 20 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.14 - MySQL Queries: 14 - Page Size: 83.45 Kb
