| Geobhoy |
 Geobhoy L Plate Warrior
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
 Posted: 21:24 - 05 Jan 2006 Post subject: |
you have just had your first experience of a seizure...
Check the oil lines and tank make sure it has 2T in it...
HAve u recently added a exhaust or different air filter ? or carburettor ??
The barrel, and or piston could have suffered damage from this too ____________________ TS 50er >CG 125>AR 125>TZR250> z200(shit heap)> ZXR750 H2 > VT500 FT >XLR250 > Mito125mk1 (unlucky strike) > TZR250 3ma > GS550 > TDR250 > GSXR750 >GS1000 > Elefant 650 > GPZ750 > FZR600>z1000 (03) > KTM 640 LC4
(Yeah i forgot some too :S ) |
| Geobhoy |
| satans_BIG_helper |
| alains |
 alains World Chat Champion
 Posted: 22:30 - 05 Jan 2006 Post subject: |
it should be more likely a lean mixture or a badly adjusted oil pump . to correct the mixture upjet your carb , clean and oil your air filter . using the pilot screw has no effect at high revs .
take off your plug and compare the colour with this link https://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
then have a good look at your oil pump
prior restarting ,by the plug hole ,drop a coffee spoon of oil , pass the 2nd gear and move the bike several wheel turn . then put a new plug and go gently for a while ____________________ the worst day fishing is better than the best day working |
| Geobhoy |
| Saint Matt |
 Saint Matt Nitrous Nuisance
 Posted: 23:12 - 07 Jan 2006 Post subject: |
Nipped a ring mate, by the soundsof it you don't know how to fix it, so I'd take it to a garage chap  |
The last post was made 20 years, 63 days ago. Instead of replying here, would creating a new thread be more useful? |
