cagiva mito engine probs?
glenbat
PostPosted: 03:23 - 21 Jan 2006    Post subject: cagiva mito engine probs? Reply with quote
been looking round for a nice 125 to learn on and several mito's state engine rebuilt and only have about 6 or 7k on the clock is this right? lovely looking bikes but dont want to buy a 6k miler only for it to give up on me the following week
RS125_Tecky
PostPosted: 05:05 - 21 Jan 2006    Post subject: Reply with quote
On an Aprilia RS 125 your meant to change the piston/rings at 8,000 kms.
Should imagine it will be the same on the mito.
Maybe these people refering to their engine being rebuilt have just changed the piston/rings.
cagiva gezzer
PostPosted: 11:06 - 21 Jan 2006    Post subject: Reply with quote
125's can let go with as little as 1,000km on the clock. It's down to luck of the draw. However, for everyone that doesn't make it past 10,000km, theres many more that make it to 30,000km.
If you do buy one that's had a "rebuild", find out what was changed and by who. Find out if they used original parts or pattern parts. Find out how long ago parts were changed, as a lot of people blow their bikes up, "fix" them and flog them on before they are run in and had a chance to fail again.
For example, a bike can seize and you can get it running with just new rings, but it won't run at normal revs without seizing agin. So ask a lot of questions about bikes that were "fully rebuilt less than 300 miles ago."
cagiva gezzer
PostPosted: 11:10 - 21 Jan 2006    Post subject: Reply with quote
You're close ish to me (hemel) and i spend a lot of time around the M25, so if you want someone to look at a 125 let me know.
Jack_Cheese
PostPosted: 15:29 - 21 Jan 2006    Post subject: Reply with quote
Eek! i'm taking delivery of a planet tomorrow that's had a rebuild. Do they use the same rotax engine as the rs125? I'm definitely going to be quizzing this guy tomorrow!
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
cagiva gezzer
PostPosted: 15:31 - 21 Jan 2006    Post subject: Reply with quote
RS's uses rotax, Cagiva's use cagiva engines.
Jack_Cheese
PostPosted: 15:33 - 21 Jan 2006    Post subject: Reply with quote
Ahaaa, i didn't know cagiva had their own 125 unit, part of me thought they might use the old suzuki RG125 unit, as the rest of the range uses suzuki engines. I should have figured, you can't go racing with someone else's engine!
Jack
The last post was made 20 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 14 - Page Size: 51.53 Kb
