Bike Stalling at lights...
DynamiteBoy
PostPosted: 08:57 - 03 Feb 2006    Post subject: Bike Stalling at lights... Reply with quote
Hi Everyone, could someone please help me understand and hopefully rectify the following problem, any suggestions welcome.
Decided to ride my CG125 in to work this morning, first long run for a while..also first run since oil change. Little traffic around allowed me to ride constantly for a good 20 minutes.
Basically the bike stalled at the first junction i had to stop at - rev's just slowed right down and the engine stopped, i pulled over to one side and for a few minutes I was unable to select first gear, also the neutral light didn’t work. After a few minutes of waiting i was able to kick her up with no problems - where she quite happily idled over as if nothing happened. So i shot off....
Next Junction same started to happen but this time I managed to catch the throttle and keep her ticking over quite fast to prevent stalling and pissing off the many cars behind me...
Any help and advice is much appreciated..Thanks, Ow
LustyLew
PostPosted: 11:09 - 03 Feb 2006    Post subject: Reply with quote
sounds like carb icing. It's been quite cold the past few days.
What you need is some Silkolene Pro FST mixed with your petrol.
Friend of mine has a CG clone and gets the same problem. So you're not alone!
veeeffarr
PostPosted: 11:16 - 03 Feb 2006    Post subject: Reply with quote
Lets all blame everything on carb icing...
Could it be the fact the oils been changed and the bike being stood for a while causing the clutch plates to stick? Does it improve when the bikes warmed up? Get the bike on the centrestand, put it in 1st and pull the clutch in, does the wheel still move? How fast?
Carb icing is quite a rare problem as far as I know... Thought CG's had carb heaters anyway.
Black Knight
PostPosted: 11:28 - 03 Feb 2006    Post subject: Reply with quote
Did you do the oil change yourself?
You sure its got enough in it? Not too much either.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
DynamiteBoy
PostPosted: 12:25 - 03 Feb 2006    Post subject: Reply with quote
Thanks for the reply’s guy's.
Yes i did change the oil my-self, I could have a little to much oil, just over the max, thought it'd be better than below.
Toby - the symptoms seem to get worse when warmed up, no probs at junctions for first 5 minutes of riding. As mentioned before the bike can be a bit tricky to start in morning, has to be choke fully OFF with a bit of throttle...
I'll have a look at the plug when i get home and post later if i see anything that might help.
veeeffarr
PostPosted: 12:36 - 03 Feb 2006    Post subject: Reply with quote
Too much oil is bad, you need to drain some.
hedjehog
PostPosted: 13:15 - 03 Feb 2006    Post subject: Reply with quote
I had a thought about the petrol. How long has it been since you last rode her? Petrol 'goes off' and when I got mine it died under throttle before I put new fuel in. Also, silly but, has it got enough in it?
Not saying it is those things (I'm no mech wizz), but worth a look.
hedjehog
1988 CG125 BRE; 2000 GPZ500S D7; VFR 800 FI-X; 1980 CB 250 RSA; 1998 FZS 600 Fazer; 1986 Honda C70 E
sickpup
Old Timer
PostPosted: 14:02 - 03 Feb 2006    Post subject: Reply with quote
Please explain to me how carb icing stops the bike going into first gear and the neutral light working?
Please explain how adding Silkolene Pro FST to the petrol will stop this happening?
sickpup
Old Timer
PostPosted: 14:04 - 03 Feb 2006    Post subject: Reply with quote
Have you ever checked the air filter?
DynamiteBoy
PostPosted: 15:29 - 03 Feb 2006    Post subject: Reply with quote
I actually replaced the air oil foam filter not long ago when i first got the bike. Bought her cheap as a project over the winter in order to learn more about bike's in general i.e. mechanics, riding etc.
I’ve replaced the spark plug/air filter/oil/ blown bulbs/ cleaned up rust and ALSO took apart my carb for inspection - guessing my problems have arisen from this over confidence.
I might just take her to a local garage and see if they can 'tweak' balance the carb, does anyone have any experience how much this might cost.
She’s been a lovely introduction to the world of biking and i would love to sell her on in good shape to another learner in the near future as on her i have already become more confident and would like something a bit bigger - maybe 400....gonna book my theory this weekend and hopefully pass my DAS in spring...
nrml76
PostPosted: 21:00 - 03 Feb 2006    Post subject: Reply with quote
Nicely explained here https://www.kgrant.co.uk/Forum/phpBB2/viewtopic.php?p=6282&sid=9ca044e78ccda702fa711c02f2d42b43
Superlight
PostPosted: 21:39 - 03 Feb 2006    Post subject: Reply with quote
Oh no! It's worse...
It must be gearbox icing!
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
RickHolt
PostPosted: 00:00 - 04 Feb 2006    Post subject: Reply with quote
I had a similar problem with the bike dying when I stop this week. Make sure the choke is fully off while riding, if it's on it could be that to blame.
Rick.
faith183uk
PostPosted: 00:33 - 04 Feb 2006    Post subject: Reply with quote
Sounds to me you need to adjust your clutch cable. Maybe as the bike is so light, as you pull up and hold the clutch in its not disengaging completely and the bike stalls out.
You would not feel the bike trying to edge foward very slightly as its so small.
DynamiteBoy
PostPosted: 08:40 - 04 Feb 2006    Post subject: Reply with quote
Rick.
The first time i rode to work - before my hanyes manual adjusting settings days - i forget to turn the choke fully off, left it half-way. It does feel like the same problem i had then, only worse...That's why i believe that the mixtures wrong. It only starts and runs with choke fully off (down). Dies if i turn it half-way or on...Does anyone know the Honda default pilot settings - im thinking Toby R might as he is a fellow CG125 owner.
Any help is appreciated...Ow
DynamiteBoy
PostPosted: 10:44 - 04 Feb 2006    Post subject: Reply with quote
Just started her up in garage, clutch in > select first > wheel spinning quite fast when lifted off floor...i dont think this is my main problems though as when approaching and stopping at junctions when shes still cold, first 5-10 minutes of riding i have no stalling cutting out problems.
If anyone didnt know i had a lot more problems on the way home, see:
[url] https://www.bikechatforums.com/viewtopic.php?t=73517[/url]
GearboxGeezer
PostPosted: 16:42 - 04 Feb 2006    Post subject: Reply with quote
I had this problem, I changed my coil and it stopped doing this, dunno if its the same problem as you lough but maybe you could get your hands on a cheap old coil ?
sickpup
Old Timer
PostPosted: 17:27 - 04 Feb 2006    Post subject: Reply with quote
nrml76 wrote:
And the prize for not being able to read a thread goes to...
mr.z
PostPosted: 18:10 - 04 Feb 2006    Post subject: Reply with quote
Was it raining?
Mine used to stop at lights too, mostly when it rained..
When sparkplugs go old/bad they will play up more when cold, try checking the gaps, if not try replace the plug and plugcap (cheap enough)
(no offence but) For the love of gawd don't touch the carbs unless you know what your doing! Shocked settings just dont go "wrong" unless they are messed with, an air leak is more likely (try spraying wd40 on any joins allong the air intakes)
You can't balance one carb btw Razz its for when you have two carbs and you need to have them feeding equal ammounts of fuel into all cylinders, i.e. you need more than one cylinder Wink
Try spraying wd40 arorund the airway (it the revs rise then theres your leak), then check/replace the plugs...
(edit: just read your other thred, not haveing much luck eh? Sad )
bidman
PostPosted: 19:12 - 04 Feb 2006    Post subject: Reply with quote
hey, sorry to point out the basics but make sure that the choke is off and that the choke lever is nice and tight and not rattling shut, choking the engine, Dan Thumbs Up
Don't ride it, RAG IT!!
dotti
PostPosted: 01:37 - 05 Feb 2006    Post subject: Reply with quote
I have the same problem on my GN, and I never have been able to get to the bottom of what causes it. What I have found, in my case, is that the problem is worse when putting the clutch straight in. If I run off the throttle, and let the bike engine brake for a few metres before using the clutch, then the bike very rarely stalls. If I put the clutch straight in, then the odds are the bike will stall.
Dangerous traffic offences spotted on 50-minute trip: Lost count after 100. Number of traffic cops spotted: One, sitting by a speed-trap camera
The last post was made 20 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 112.95 Kb
