Mouth Ulcers!
Marcg868
PostPosted: 17:07 - 09 Mar 2006    Post subject: Mouth Ulcers! Reply with quote
Basically ive got two massive ones on top left side and bottom right, both near the really pointy looking vampire tooth! And just want to know, ive tried everything for getting rid and they havent started to heal or anything. Tried bonjella, listirine mouth wash gets rid of the white stuff n then they bleed a bit, but they're just so painful, can hardly eat without my eyes watering. Crying or Very sad
JACK, MISS YOU LOADS YOU LEGEND.
veeeffarr
PostPosted: 17:17 - 09 Mar 2006    Post subject: Reply with quote
Mouthwash with Hot (Read: Hot as you can take, so f*cking hot) salted water.
veeeffarr
PostPosted: 17:18 - 09 Mar 2006    Post subject: Reply with quote
Also while you're at it you need to take a look at your diet/stress levels, as poor diet and extreme stress are a good cause of ulcers.
flat spot
PostPosted: 17:22 - 09 Mar 2006    Post subject: Reply with quote
You're just overtired. Probably coming down with a cold or something. "Adcortyl" is the stuff you want for your ulcers. Put it on at night and things will be noticeably better in the morning. Thumbs Up
JonB
Afraid of Mileage
PostPosted: 17:29 - 09 Mar 2006    Post subject: Reply with quote
Many people think that when you bite your lip you will definately get an ulcer, partly true but usually it will just heal up naturally, but if you are a bit run down/stressed it is more likely to turn to an ulcer.
Annabella
Like a person, only smaller
PostPosted: 17:33 - 09 Mar 2006    Post subject: Reply with quote
If they are larger, or a similar size to the nail of your little finger then you should go to the doctors.
Mouth Ulcers that don't clear up and/or are large are usually a result of something else being wrong with you. It may just be that you are generally run down or tired, but it is possible that there is something more seriously wrong - ie. some kind of infection.
Are you feeling well in every other way?
Avast! Pirates ahoy!
I did Cadwell! Very Happy
colin1
Captain Safety
PostPosted: 20:37 - 09 Mar 2006    Post subject: Reply with quote
to fight any infection your body needs water
drink at least 2 litres a day
swilling vodka or very salt water around your mouth will help to kill the infection but might sting a bit
stop eating sugary foods as the bugs feed on sugar
Handsome
PostPosted: 20:42 - 09 Mar 2006    Post subject: Reply with quote
When they first start, Mint Toothpaste helps/can get rid of them ( put some on your finger and rub it on )
It also takes the sting out of them aswell.
Katie
PostPosted: 21:51 - 09 Mar 2006    Post subject: Reply with quote
Wet you finger, dip it in salt, put it straight on the ulcer. That bad boy will sort it right out, but will probably make you cry. So .. the question is, how much of a man are you? Laughing
That's what I do anyway, dries it up and goes in about a day.
Never have a row with an Idiot, they drag you down to their level then beat you with experience.
nrml76
PostPosted: 22:46 - 09 Mar 2006    Post subject: Reply with quote
Corsodyl mouth wash 4-6 times a day. It really works. Trust me.
Annabella
PostPosted: 10:24 - 10 Mar 2006    Post subject: Reply with quote
It will really hurt though!
If it doesn't start to heal it up, then you really should get to see a doctor.
Katie
PostPosted: 12:30 - 10 Mar 2006    Post subject: Reply with quote
It does! The trick is to dance around the kitchen going "Ohh ow, ow ow oohh ahh ow." while it stings. That's what I do. Laughing
Marcg868
PostPosted: 19:22 - 10 Mar 2006    Post subject: Reply with quote
Tried salty water!!!! it was foul and stung like a bastard, stung more than when i snapped my leg in half! I do eat a bit of sugar so thats probably why i get them quite bad. My diest not the best but i do enjoy alot of fruit and water, but bit of a chocoholic too!
And yeah i have been tired and only this month recovered from a very bad stomach bug i got. So not 100% yet!
Kwaks
I'm not a fast rider
PostPosted: 13:01 - 11 Mar 2006    Post subject: Reply with quote
Sounds like this is a recurring problem, as Annabell said see your quack,this can be a sign of something else,eg the stomach bug could still be there and causing problems in your whole digestive system. Also mention it to your dentist,he will check out the proximity of your canines to the ulcers to see if they are causing it. It may be that they are a bit sharp and rubbing on your gums,especially if you have an overbite.
Could simply be the helmet pushing your gums into the teeth at these points Question
hellkat
PostPosted: 01:58 - 12 Mar 2006    Post subject: Reply with quote
And no unprotected oral sex with attractive strangers till they've healed up Shocked
Marcg868
PostPosted: 17:00 - 12 Mar 2006    Post subject: Reply with quote
Starting slowly and surely healing up! Ive always had a problem with ulcers, and i have two very sharp vampire looking teeth, which i think is why i get them! I end up biting my cheek n then getting massive ulcers!
But the salty water n listirine is helping, so thanks for the advice.
Im not fully sure its gone this bug, my gf has still got it also. She got it 3 weeks after me, n still has. This is since end of january.
hellkat
PostPosted: 17:38 - 12 Mar 2006    Post subject: Reply with quote
If you're always getting them, you should perhaps look at your nutrition.
I notice when I am not eating enough fruit or vegetables that the sides of my mouth get cracked, like cold sores but not. It's often a sign that you're run down. Once I start eating proper food with proper vegetables etc., instead of just pot noodles/pasta/rice/cornflakes/toast in the middle of the night Exclamation Laughing then it clears up and goes away.
The "vampire"/fang teeth are described as "canines" by dentists (for fairly obvious reasons, I would have thought).
MarkyPancake
PostPosted: 22:38 - 12 Mar 2006    Post subject: Reply with quote
Bonjela works for me when I get them. Thumbs Up
The Tot
PostPosted: 23:10 - 12 Mar 2006    Post subject: Reply with quote
If your a masochist, try this. Dip a gumshield in salt and then suck the hell out of it. You will cry and it WILL hurt. Also notice the amout of dribble that comes out as a result. I usually think it's a good thing. Following this, i use bonjella a keep my mouth wide open. I use the gumshield because when i do get mouth ulcers, i tend to get shit loads of them at the same time due to vitamin deficiencies.
Try to eat bananas and lots of salad after. It seems to cure the ulcer quicker for me than if i'm larking about. Also, be very careful not to BITE the ulcer because it just makes it worse. If this is not alreaady apparent, then you should just try to scoop the ulcer out with a knife or summat.
Trust me, rub salt deep into the ulcer till you cry and then put bonjella over it. You'll lose all sensation of touch but it'll feel smooth.
Never argue with autism
Marcg868
PostPosted: 01:05 - 13 Mar 2006    Post subject: Reply with quote
Banana's work a treat, they usually help them clear up quicker. I have a thing for them, eat about 4/5 a day Very Happy tried the gum shield thing titz Sick its not pleasant but it works and my god ive never had my eyes water so much Shocked but they're clearing up which is a good thing.
Simple
PostPosted: 13:06 - 16 Mar 2006    Post subject: Reply with quote
mouth ulcers can be caused by infection, there are over 10 000 000 bacteria in your mouth, most of those are there purely to out compete pathogens (unfeindly bacteria) which you come into contact with, what starts off as a little ulcer could become larger due to these pathogens getting into the ulcer which is the same as a cut in your skin, if you are run down/tired/stressed or recovering from illness you are more at risk of ulcers, and the larger ones.
if the ulcer is particularily bad/large may be worth going to docs, though taking anti biotics for a mouth ulcer is not to be advised.
I put tooth paste on them, hurts like hell but I like the tast of bonjela and find my self inadvertently licking it off Embarassed
Insta - FemFeral
Marcg868
PostPosted: 18:39 - 16 Mar 2006    Post subject: Reply with quote
I love Bonjela too, Aniseed Mmmmmmmmmmmmm, bit like Ouzo in a tube Very Happy Got some Pastey stuff from my Dentist plus a scrape and polish of me teeth £25 Crying or Very sad
Simple
PostPosted: 18:42 - 16 Mar 2006    Post subject: Reply with quote
Ahh the joys of being a full time student
Had my check up yesterday, had an exray, and that was it. all is well.
so to date I have no fillings, cavities or anyother nasties.
The x-ray showed that I have no lower Wisdom teeth, Result!
That's evolution for ya! Cool
Insta - FemFeral
Marcg868
PostPosted: 01:17 - 17 Mar 2006    Post subject: Reply with quote
Jammy gett! wish i was still in full time education, My Mrs is and she loves to gloat at me Evil or Very Mad Ah well, my Wisdom teeth are all through, and ulcers are healing nicely, just need balance my diest more and sleep better.
Dragonfly
PostPosted: 14:13 - 21 Mar 2006    Post subject: Reply with quote
eating to much sweet stuff cause ulcers for me.
but i have been plagued with them since childhood and then i found out i was a coalic and i was allergic to wheat and gluten and that was one of the reactions my body was taking horrible fecking mouth ulcers! since i dont eat wheat or gluten anymore i dont get any of the horrid things i used to.
have it checked out anyway.
All the breast.
Muzza on Binge:
The last post was made 20 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 126.64 Kb
