| tatters |
 tatters Exxon Valdez
 Posted: 22:20 - 02 Apr 2006 Post subject: Front caliper replacement |
The caliper on my 1981 Z200 is utter crap (cable operated disk) and is worst at braking than my dads 1957 C12, would it be possable to retro fit a later hydrolic system from a more modern bike if l just find something with the same fixing distance for the fork leg?
Has anyone ever done a simular retro fit or would it be easyer to replace the whole front end? ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Kickstart |
 Kickstart The Oracle
| owdamer |
 owdamer World Chat Champion
| stinkwheel |
 Posted: 22:43 - 02 Apr 2006 Post subject: |
1981 bike just needs a brake light switch on the rear.
You could probably modify the backing plate off a sliding calliper to fit (might need to make some spacers). The hole centres on the backing plate for a GPZ500 sliding twin pot calliper are 56mm apart.
Might be worth swapping the fork legs round too so the lugs are along the back of the fork leg. This puts the braking forces through the fork leg rather than through the metal of the lug itself. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tatters |
 Posted: 22:48 - 02 Apr 2006 Post subject: |
l,ll go down the breakers on saturday with the caliper and a vernia and have a hunt through the boxs, as long as l can get the right caliper l guess l can just find any old brake line and lever/master cyclinder that fits the bars and caliper. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| stinkwheel |
| nrml76 |
 nrml76 Brolly Dolly
| tatters |
 Posted: 22:25 - 03 Apr 2006 Post subject: |
| nrml76 wrote: | If you are buying salvaged parts, why not get a suitable pair of forks, along with the brake calipers? |
Too expensive the breakers around here take the piss when it comes to forks, the front brake lever is part of the right hand switch gear so l,m going to have to get a right hand switch gear too.
from memory l would be looking at
switch gear: £5
caliper: £10-20
Hydrolic pipe: (got stock KR-1S pipes somewere)
master cyclinder and lever: £10-20
maybe £25-45 total for the reto fit, would be worth it saftey wise.  ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Zimbo |
 Zimbo World Chat Champion
| stinkwheel |
 Posted: 01:10 - 04 Apr 2006 Post subject: |
You can get spacers made up out of some alloy to fit nearly any calliper onto your bike. Here's a picture of the spacer I had made for my KLE when I put an ER5 wheel in it. (Luckily I know a guy who likes playing with machine tools so he did it cheap). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ZRX61 |
 ZRX61 Victor Meldrew
| stinkwheel |
 Posted: 12:31 - 04 Apr 2006 Post subject: |
I wonder if a GPz305 front end would fit? They have twin discs and there should be loads of them out there with blown engines so intact cycle parts should be reasonably common.
Front ends are usually so expensive in breakers because most people bend the forks when they crash their bike, this is why they are in the breakers to start with. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 19 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.5 - MySQL Queries: 14 - Page Size: 75.05 Kb
