Wheels sticking
Noggin
PostPosted: 22:04 - 04 Apr 2006    Post subject: Wheels sticking Reply with quote
Hi all.
I've been finding that when I go to move the bike in the morning or after its been standing a day or two that the wheel sticks and i have to give the bike a shove to get it to free up. Any ideas as to what the problem is?
I've thought either the brakes are binding or the bearings are?
Cheers all
Craig G(Noggin)
Current bike: kawasaki zx12r 2002
Track bike: yamaha r6 1998
Old Bike: honda NSR 125 1998
meooo
PostPosted: 22:55 - 04 Apr 2006    Post subject: Reply with quote
If you put it away when damp, the pads can cause localised corrosion and stick to the discs (as pads contain tiny iron filings), no real cure except try a different make of pad, some are worse than others. Wouldn't expect a bearing to cause it tbh.
Other cause could be a caliper piston sticking or pads tight/corroded into the caliper and causing it to stick.
Noggin
PostPosted: 23:06 - 04 Apr 2006    Post subject: Reply with quote
OK, I'll look into it...
Thanks for the help tho!
PostPosted: 23:10 - 04 Apr 2006    Post subject: Reply with quote
As above, but generally FAR worse if you have cast iron disks (and loads of aftermarket replacement disks are cast iron).
ZZR-Souls
PostPosted: 14:57 - 05 Apr 2006    Post subject: Reply with quote
Dont use sintered pads in the winter. The high metal content combined with road salt can corrode the disks overnight and cause serious scarring of the disk surface leading to premature wear.
JOIN IN THE BIGGEST RIDE-OUT OF 2007 here
The last post was made 20 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.92 - MySQL Queries: 14 - Page Size: 43.94 Kb
