| loply |
 loply World Chat Champion
 Posted: 19:12 - 08 Apr 2006 Post subject: Fork assembly problem :( |
Hi folks,
I took one of my USD forks from my Yamaha SZR660 (same forks as the TZRs) apart today to change the fork seal. Ive done this job once before.
When I go to reassemble the fork, when I bash the gold ring with the teflon inner coating into the fork tube, the slider gets stuck.
As soon as you bash the gold thing half way in or more, the slider gets totally stuck solid and is a bastard to remove again.
Any idea what this could be? Its driving me insane, I hope I dont need new forks.
Ill post a pic tomorrow.
Rich ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| zenodamper |
 zenodamper Derestricted Danger
 Posted: 23:07 - 08 Apr 2006 Post subject: |
...this gold bit with inner teflon coating would be the guide bushing, right? If it is getting stuck, you will most likely be needing a new one, and some dressing on the seat... Maybe getting a set of fork seal drivers would be a better way to put the stuff back in... save more future problems from happening.  |
| loply |
 Posted: 17:42 - 09 Apr 2006 Post subject: |
The guide bushing yeah, its not getting stuck itself - The bushing goes in fairly easily, but once its in, the fork wont slide... ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| zenodamper |
 Posted: 23:22 - 09 Apr 2006 Post subject: |
Ya, and on the flip side of your problem, is the bushing that goes in easily enough; but the fork gains another kind of problem - in other words, the tolerance/clearance is quite important... so, take a good look at which bit has the problem, the bushing or its seat, and more than likely you will need to change that bushing.  |
| loply |
 Posted: 00:15 - 11 Apr 2006 Post subject: |
How much does a guide bushing cost normally? ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| zenodamper |
| loply |
 Posted: 18:40 - 11 Apr 2006 Post subject: |
Replacement guide bush is around £20, but the guy at the parts shop reckoned a worn guide bush would cause free play in the stanchion, rather than causing it to jam...
I kind of agree with that theory; Why would a worn bush cause it to jam?
Then again, what else could it be?
I don't have £20 to waste if it's not the bush, but I can't explain it really... Any other thoughts at all? ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| zenodamper |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| loply |
 Posted: 19:47 - 11 Apr 2006 Post subject: |
No, I only took one fork apart, and put the same parts back in. Ive only put two parts in (upper bush and lower bush), so theres no question of things being in the wrong order...
Its ridiculous - It slid before, so why doesnt it slide now? ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Nath |
 Nath World Chat Champion
| cagiva gezzer |
| loply |
 Posted: 17:51 - 12 Apr 2006 Post subject: |
I bash it in evenly until it fills its seat, so it must be square.
Im going to remove the bush later this evening and closely examine it for damage, twisting etc. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
The last post was made 19 years, 315 days ago. Instead of replying here, would creating a new thread be more useful? |
