Does Latex Stretch ?
culpan
PostPosted: 21:28 - 18 Apr 2006    Post subject: Does Latex Stretch ? Reply with quote
Before anyone asks I HAVE NOT purchased a gimp suit, but rather a Dry cag for kayaking.
My question is how much will latex stretch, as currently when round my neck i turn all red. Will latex give a little and if so how much.
Whosthedaddy
PostPosted: 21:29 - 18 Apr 2006    Post subject: Reply with quote
It will stay tight with a little give after a while
cagiva gezzer
PostPosted: 21:42 - 18 Apr 2006    Post subject: Reply with quote
Did you not go to school?
https://www.2step-garage.co.uk/images/napa2000/dale_condom.jpg
FreshAL
Sir Crashalot
PostPosted: 21:55 - 18 Apr 2006    Post subject: Reply with quote
It should be quite tight, it's got to keep water out!
You've got 3 choices
1) Live with it. As long as you don't go blue and pass out you'll be fine.
2) Push a football into the neck seal and leave it for a while. This will help stretch the latex out.
3) On the latex seal you'll see 'rings' running around it. With a VERY sharp scalpel trim a 'ring' of latex off. You're probably best to ask at your local kayaking shop for advice before you try this, as it's pretty easy to split the seal if you get it wrong.
If you want more answers try asking on www.ukriversguidebook.co.uk/forum
carlnicholson...
PostPosted: 00:30 - 19 Apr 2006    Post subject: Reply with quote
I tried a dry cag when I was kayaking. I couldn't breath!
Instead, I bought a semi dry cag, which has neoprene collar and cuffs with a velcro adjustment on the collar. It wasn't 100% water tight if fully submerged, but I had a wet suit on underneath anyway, so I was still warm when wet.
Give one a go, they are normally a bit cheaper that fully dry ones aswell. Thumbs Up
"THOSE WHO RISK NOTHING, DO NOTHING, ACHIEVE NOTHING, BECOME NOTHING."
The last post was made 20 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 44 Kb
