xr125l carb drain ?
fender62
PostPosted: 23:13 - 20 Apr 2006    Post subject: xr125l carb drain ? Reply with quote
i need to drain the carb on my honda xr125L i know theres a screw
that has to be undone but where is it exactly, anyone have a pic of it etc ie carb and screw in a pic with if possible an arrow pointing to screw.
sickpup
Old Timer
PostPosted: 23:32 - 20 Apr 2006    Post subject: Reply with quote
On the bottom of the float bowl which is the bottom of the carb if there is one.
https://www.bigbuckatvproducts.com/images/Mikuni/BST40.gif
Item 50 is a drain screw and item 46 is a drain plug, your carb could have either or both.
fender62
PostPosted: 23:39 - 20 Apr 2006    Post subject: Reply with quote
do i remove 50 or 46 or both, and i guess have a small cup or bowl below it ?
NSR Mick
PostPosted: 23:43 - 20 Apr 2006    Post subject: Reply with quote
why do you need to drain it? removing 46 will allow you possibly scrape gunk out from inside the float bowl, although I wouldnt advise it as you may damage the float.
sickpup
Old Timer
PostPosted: 23:45 - 20 Apr 2006    Post subject: Reply with quote
That isn't a pic of your carb. Use it to see if you have a screw or a plug and remove whichever you have but turn off your fuel at the tank first.
NSR Mick
PostPosted: 23:48 - 20 Apr 2006    Post subject: Reply with quote
I thought you had been super efficient there sickpup and found the correct diagram. Embarassed
In most cases you will only have no 50. just turn your fuel off and unscrew it, or leave it on to flush the bowl out a bit.
sickpup
Old Timer
PostPosted: 23:52 - 20 Apr 2006    Post subject: Reply with quote
Yeah right.
You have GSXR in front of your name and didn't recognise that carb? amateur Rolling Eyes
fender62
PostPosted: 00:00 - 21 Apr 2006    Post subject: Reply with quote
thansk again so just unscrew no50 and see what comes out, other than a little petrol what possibly would come out ?
sometimes when i start bike it will idle for a few seconds then cut out then i have to start again, its not the choke it has fresh petrol
bike is only three years old.when it does eventually go it ok
NSR Mick
PostPosted: 00:03 - 21 Apr 2006    Post subject: Reply with quote
sickpup wrote:
Yeah right.
Dont have it anymore and never needed to look at them (couldnt be arsed) Embarassed and mine didnt have bungs.
and maybe i had an injected gsxr not that I did.
The last post was made 20 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.8 - MySQL Queries: 14 - Page Size: 58.97 Kb
