Spot the difference
Rookie
PostPosted: 18:55 - 13 May 2006    Post subject: Spot the difference Reply with quote
https://www.bikechatforums.com/files/0805_011.jpg
Spot the difference!
Aside from being horrifically dirty, and having a chunk out of the side of it, I found today that my old sprocket cover, which I finally got around to changing, was missing the spring present in the new (clean and shiney Cool ) one.
What does it do? I haven't ridden the bike yet, I'm quite low on petrol. Again. Rolling Eyes The bike's always ridden well, and the clutch has been OK besides the slipping problem, and I'm sure the lack of this little spring can't be the cause of that. Though I wish it was. Laughing
White Noise
Mr Dudwee
PostPosted: 19:03 - 13 May 2006    Post subject: Reply with quote
it looks like a spring to "pull" back the clutch cable to make sure that the clutch is fully engaged. not sure it would cause clutch slip but i'm not writing it off. i'm sure that kickstart could claify
WN
Rookie
PostPosted: 19:06 - 13 May 2006    Post subject: Reply with quote
Yeah, the mechanism of it seems to be that it will pull the wire further into the sprocket cover. I'm not quite sure on how the wires work when it's all shoved together, so I don't know how the missing spring is significant. Confused
Just to clarify; in the old sprocket cover, the thing which the clutch cable hooked into moved freely either way. No resistance.
Lone-Wolf
PostPosted: 21:24 - 13 May 2006    Post subject: Re: Spot the difference Reply with quote
Rookie wrote:
What does it do?
Wotcha.
It's the spring that returns the clutch operating mechanism - very similar to the ones used in the BSA Bantam many moons ago.
Cheers.
L.W. - www.moonshiners.org.uk
Guest
PostPosted: 21:25 - 13 May 2006    Post subject: Reply with quote
https://img.photobucket.com/albums/v471/fastfitter/Cat.jpg
Your clutch cable pulls upwards (left in the pic) and the worm drive moves out to push the clutch pushrod and operate the pressure plate against it's springs.
When you let go of the lever, the pressure plate will push the pushrod back and close the worm up again. The little spring is just an extra to make sure the worm returns to 'rest' and the slack in the cable is taken up, otherwise you'd get a floppy lever if the worm got stuck up with chain gunge or what-have-you.
The last post was made 20 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.74 - MySQL Queries: 14 - Page Size: 44.64 Kb
