Headphones/earphones.....
Hotdog
PostPosted: 12:58 - 19 Jun 2006    Post subject: Headphones/earphones..... Reply with quote
I've recently purchased some Koss 'The Plug' earbuds.
These are described as 'maximum isolation'.
While it's very difficult to actually measure noise attenuation I can very obviously directly compare them to normal foam earplugs.
I would class the attenuation provided by them as somewhere between 'poor' and 'non-existent'.
Not really what I would class as 'maximum isolation'.
Possibly you might not be able to hear background noise if you used them for music and had it cranked right up.
Basically I need a set of earphones that cut out as much background noise (wind noise) as possible.
Any ideas anyone ?
TIA.
Hotdog.
He's a gentleman, a scholar, he's an-acrobat, he's the one and only truly original.......
Hotdog....(Defender of the weak, the poor and the innocent)
He's The Ace - He's Amazing...He's the Strongest... He's The Quickest.... He's The Best!
mr.z
PostPosted: 13:04 - 19 Jun 2006    Post subject: Reply with quote
The best are moulded to your inner ear and very expensive Sad (£150+?)
I had great results out of my sony in ear ones, not as good as earplugs but not bad, only thing is they aren't overly comfortable with the helmet i have at the moment...
Hotdog
PostPosted: 13:13 - 19 Jun 2006    Post subject: Reply with quote
What model are they ?
Cheers.
mr.z
PostPosted: 13:21 - 19 Jun 2006    Post subject: Reply with quote
https://www.aerostich.com/product.php?productid=17095&cat=337&page=1
These are the ones i was on about, there not actually to bad compared to how much there were... theres a uk company make similar..
The sony ones... ummm. tbh i've managed to missplace mine Rolling Eyes
They look this though.. fontopia? something like that...
https://www.sonystyle.com/intershoproot/eCS/Store/en/imagesProducts/MoreImages/MDREX71SL_1.jpg
Hotdog
PostPosted: 13:36 - 19 Jun 2006    Post subject: Reply with quote
The Koss ones look like this:
https://i26.photobucket.com/albums/c117/hotdog451/Koss.jpg
They sure do look comfy, don't they ?
Unfortunately they are vented, they have drillings in the back to allow the diaphragm to respond, I'm pretty sure this is why they are useless at attenuating noise.
Hotdog.
NicM
PostPosted: 14:06 - 19 Jun 2006    Post subject: Reply with quote
Anyone know of a decent comportable pair of earphone's. I find with the in ear one's in my lid the press to hard against my ears and after about an hour of riding there just to sore to wear.
Hotdog
PostPosted: 14:07 - 19 Jun 2006    Post subject: Reply with quote
Hey, don't hijack my thread !!
JonB
Afraid of Mileage
PostPosted: 14:14 - 19 Jun 2006    Post subject: Reply with quote
Yeah they are good, brilliant bass but mine blew up within 3 months.
Rookie
If you really want to block out background noise, you need noise-cancelling ones. They cancel out the frequency of the background noise, I'm not going into the science of it again, because I get it wrong. Laughing
The standard Sony in-ear noise cancellers cost from about £80.
The best non-cancelling, budget earphones on the market as far as I'm concerned are the Sony in-ears. The old model was the MD-EX71, and the new model is MD-EX81. The 71s are absolutely superb, however I'm yet to try them on a bike. I can't imagine any problems, however.
PostPosted: 14:16 - 19 Jun 2006    Post subject: Re: Headphones/earphones..... Reply with quote
I believe the earphones you have got can be 'modded' to use a standard ear plug, which may provide a bit quieter enviroment.
This place might be worth a look....
https://www.diycustomplugs.com/
They are moulded ear plugs which you can do yourself at home. They can be moulded around headphones as well, it seems.
Tempted to give them a try sometime myself.
Hotdog
PostPosted: 15:07 - 19 Jun 2006    Post subject: Re: Headphones/earphones..... Reply with quote
Earphones 'who' has ?
PostPosted: 15:16 - 19 Jun 2006    Post subject: Re: Headphones/earphones..... Reply with quote
You.
May have been a different model/brand, but pretty sure it was Koss ones at least.
Try a search for 'koss' on here, maybe?
Hotdog
PostPosted: 15:20 - 19 Jun 2006    Post subject: Re: Headphones/earphones..... Reply with quote
G wrote:
You.
Hi G,
Unfortunately, they are vented, they have drillings in the back to allow the diaphragm to respond, I'm pretty sure this is why they are useless at attenuating noise.
I've found advice on replacing the rubber 'plug' part with foam (from a different brand) or making your own foam plugs out of earplugs, but I really don't think this will make any difference (other than comfort).
Hotdog.
d8ncer
PostPosted: 16:02 - 19 Jun 2006    Post subject: Reply with quote
The best are moulded to your inner ear and very expensive (£150+?)
Have a look at www.diycustomplugs.com
Link to fitting videos for the products on product pages.
Hotdog
PostPosted: 18:10 - 19 Jun 2006    Post subject: Reply with quote
I can't find any working video......
d8ncer
PostPosted: 18:13 - 19 Jun 2006    Post subject: Reply with quote
Link Below
https://www.diycustomplugs.com/fitting_pod_plugs.html
Velocifero
PostPosted: 18:17 - 19 Jun 2006    Post subject: Reply with quote
Take a look at the SURE website
https://www.shure.co.uk/PersonalAudio/Products/Earphones/index.htm
Hotdog
PostPosted: 18:18 - 19 Jun 2006    Post subject: Reply with quote
d8ncer wrote:
Quicktime is missing software required to perform this operation.
Andy C
Tree Seeking Missile
PostPosted: 18:33 - 19 Jun 2006    Post subject: Reply with quote
The headphones i used (ones Mr Z have posted) to have (sony £30 ones) good for the money but i have some and wouldnt get another pair Thumbs Down within a month the rubber on the wire same off, still work fine but taking a helmey off near them makes it happen. a friend of mine had the same problem. They are good for 90mph though and dont let the wind in much
Heres is what mine look like now, also the wire tingles on the back of your neck and mean i needed a neck warmer on while off the bike to listen to them Rolling Eyes
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00091.jpg
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00092.jpg
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00093.jpg
I now have Etymotic Research ER6 headphones and there much better, cheapest they go for is £65+ but im into my headphone so pay this much. If i could go back i would have brought the Etymotic ER6i ones, very simular but smaller ear pods and the range of aftermarket bud are wider for the smaller ear cannal. The ER6 only has foam but ER6i had foam and 2 different rubber one Thumbs Up
I brought new small foam filter which were quite expensive (£10 for 4-5 pairs)
I the pic is the carry case, medium + small foam earbuds, Rubber medium bed, filter changing tool, earphones
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00094.jpg
The foam is what i use, the rubber is how they come. easy to change over
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00095.jpg
In my ear
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00096.jpg
These are my recommendation if you have the money, i know a fair about headphones so any questions that you have i try to answer
Hotdog
PostPosted: 18:46 - 19 Jun 2006    Post subject: Reply with quote
(Pictures snipped)
(Pictures snipped)
Hi Andy,
I'm now considering the ER6i or the Shure E4c or E3c.
Obviously a real world test is worth it's weight in gold.
Have you tried them just for attenuation ?
How much background noise do they block out ?
Cheers.
Get on with your recovery !!
Mike.
Andy C
PostPosted: 18:53 - 19 Jun 2006    Post subject: Reply with quote
afriad these were brought after the crash so havnt used them on the bike but used the sonys a lot and think the ER6 would stand up better as go deeper into the ear.
HOWEVER, if i could buy them again i would defernetly get the ER6i, i have small ear cannals so had to get small ear buds and ER6i's have small rubber ones but ER6 dont.
The ER6i are also smaller as think they would be much better for biking Thumbs Up. They also say on the site they have better bass response than the ER6 which will make the difference at high speed as treble is very hard to hear high speed IMO.
I would go for ER6i if i was you, i think the ER6 are excellent sound insolators so im sure the ER6i would be just as good. But remember with earbud earphones they are only good if you get them to fit into your ear really snug and well Thumbs Up
Also, dont get them in white, black defernetly. White go off-white very quickly and just look horible Thumbs Down
And im pritty sure the ER6i's will be great at speed
Hotdog
PostPosted: 19:19 - 19 Jun 2006    Post subject: Reply with quote
Real-Ear-Attenuation-at-Threshold (REAT) Measurement Method
The ANSI standard method of measuring the noise attenuation of hearing protectors and earphones is to compare the quietest sound that can be heard with the earphones in place to the quietest sound that can be heard with the ears open. This Real-Ear-Attenuation-at-Threshold (REAT) method is the basis for all OSHA Noise Reduction Ratings (NRR). ER-4 and ER-6 earphones were measured with the REAT method at E-A-RCALSM Laboratory, Indianapolis, IN. Virtually identical results were obtained on these earplugs by the TNO laboratory in the Netherlands.
Probe Microphone Measurement Method
Active noise-canceling earphones cannot be measured with the REAT Method because their circuit noise interferes with the measurement. ER-4 and ER-6 earphones were compared to active noise-canceling earphones using a probe microphone method: A calibrated 84 dB SPL broad-band pink noise was generated in a reverberation room using four uncorrelated noise sources. The sound pressure developed in the ear was measured with a 2.5 mm microphone located deep in the ear canal. The noise reduction of each earphone was calculated as the difference between the noise level in the open ear and the noise level with the earphone in place.
Ok...so that's how it's measured.
But...what is the actual (or claimed) attenuation ?
ER•6i Technical Specifications
Frequency response: 50 Hz to 16 kHz
Tolerance: ±3 dB to 6 kHz, ±6 dB to 16 kHz re nominal
Transducer type: Balanced armature
1 kHz sensitivity: 108 dB @ 0.1V
Impedance: 16 Ohms
Maximum output: 120 dB SPL
Maximum continuous input: 2.5 Vrms
Weight: less than 1 oz.
No mention of attenuation in the specs ????
Andy C
PostPosted: 19:30 - 19 Jun 2006    Post subject: Reply with quote
i dont know, all i can say if the sony ones were pritty good as keeping the music ok till 90mph. ER6's are better (as hear less when walking etc) and better fit so think they will be great. My helmet wasnt quiet so think they did a good job Thumbs Up
The ER6i's are my recommendation. I was also close to getting the Share E2c aswell as look good.
I deferenetly think earphones that go into your ear at £50-70 price range are what work well for riding. Of course more expensive would be even better but not needed Thumbs Down
Hotdog
PostPosted: 20:06 - 19 Jun 2006    Post subject: Reply with quote
Hi Andy,
The problem is I want to keep my hearing.
If I set the volume so that it is reasonable when still, it is drowned out by wind noise when moving.
I have to set the volume so that it is painfully loud when still to have any chance of hearing it when on the move.
This demonstrates to me that there is not enough isolation with the Koss.
I guess you won't know how good your etymotics are until you can try them on a bike.
Hotdog.
Andy C
PostPosted: 20:17 - 19 Jun 2006    Post subject: Reply with quote
yes this is a major problem i found but i dont have music that loud that is why i have tried so many headphones (about 6th pair). The sonys didnt need to be turned up to much at all and still hear the music at higher speeds. Though it wasnt as good quility as i wanted so invested in these headphones.
I think they wont need turning up and filter all the noise on the bus that im currently having to catch to get to college and very good sound quility, noticing parts of songs i havnt noticed before as reproduces the sound so well Thumbs Up
It a shame you cant borrow mine for the day, if you were nearer Thumbs Up
The last post was made 20 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.73 - MySQL Queries: 16 - Page Size: 147.77 Kb
