Shed roofing
chris___
PostPosted: 21:44 - 31 Jul 2006    Post subject: Shed roofing Reply with quote
Anyone got a rough idea of how much shed roofing felt costs? Im doing up my old battered shed and turning it into a little bike workshop and need to get hold of some roofing felt.
Cheers!
Yamaha rxs100 > Kawasaki ZZR600 > Kawasaki ZX6R > Honda Hornet 600 > Honda Bros 400 > Suzuki SV650S K2
Bikepics page
daz|n00by
The Internet
PostPosted: 22:12 - 31 Jul 2006    Post subject: Reply with quote
Cheap felt known as sarking felt or under felt is about £5/7
Then you have a top felt known as green mineral felt this is a lot thicker and comes with a kind of gravel finish to help prolong life this is between £15/20
Both the above need fixing with either clout nails (galvanized) or a pre bonding agent like a bitchamen (sp)
Then you have imo the best wich is called torch on felt, this is like green mineral to look at but has a bitch under coat on it which when heated with a large blow torch will stick to the wood of the roof its self and make a water tight seal.
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
chris___
PostPosted: 22:49 - 31 Jul 2006    Post subject: Reply with quote
Cheers Daz Thumbs Up
So its just a case of nailing the two layers together with clout nails ate end of the felts to the shed, or are they already nailed together before I fix it to the roof?
Bikepics page
daz|n00by
The Internet
PostPosted: 22:58 - 31 Jul 2006    Post subject: Reply with quote
go lenght ways on the roof even if its a flat roof or a apex roof.
so you start with the bottom length and nail it then you over lap the next lenght to cover the nails uyou just put in, and carry on untill just below the ridge on a apex roof, if it is apex you then do the other side the same and the last peice will lay over the ridge and cover both each sheet you just laid on both sides, Confused
thats sounds a bit confussin doesnt it?
maybe this sounds simpler.
when putting the felt on the roof dont go from side to side with each lenght of felt, instead go from the front of the shed to the back with each lenght of felt.
The last post was made 20 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 14 - Page Size: 40.4 Kb
