brake disc iffy
Itchy
PostPosted: 14:00 - 04 Aug 2006    Post subject: brake disc iffy Reply with quote
I just had a look at my brake disc on the front , one side looks all shiny and metalic , the other all black and a bit scored, its supposed to wear evenly and hence be shiny on both sides right? ,
This is generally an indication to strip down me caliper and adjust the brake pads before ruining my front disc right?.
Any suggestions?
Thanks
craigs23
Mr Muscle
PostPosted: 15:08 - 04 Aug 2006    Post subject: Reply with quote
As mentioned, have a look at the pads/calliper condition.
The discs shouldn't be overly shiney - too much would indicate a glazing. They should look clean, not too coloured, and have a very slightly 'worn' feel to them - but no gouges, rings or raises edges.
garry
PostPosted: 00:10 - 06 Aug 2006    Post subject: disc Reply with quote
as said ,, time to remove caliper/ check pads i suspect there knackered, also now you can check caliper out. is it one or two piston ? either way make sure piston/s move freely.
read yer manual.. and replace new pads
have fun
so long so long so long and thanks for all the fish !
The last post was made 19 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 14 - Page Size: 36.36 Kb
