Dropping an engine.
GearboxGeezer
PostPosted: 23:41 - 06 Aug 2006    Post subject: Dropping an engine. Reply with quote
Heya,
Does anyone have any advice on how to drop an engine by yourself? Its an rs 125 if that helps.
Basicly you have to take the rear swingarm bolt out, and im really strugling to get it out, What should I do?
Thanks.
PostPosted: 23:56 - 06 Aug 2006    Post subject: Reply with quote
Best way is usually to get a friend to help.
One person lifts and wiggles the engine while the other pulls the engine bolt. DO NOT push the bolts through with your finger, use a socket extension bar or something.
You can use a car jack to take the weight while you remove the bolts if you can't get someone else to help.
Then just lift it out, a 125cc 2-smoke motor is light enough to lift out by yourself providing you get a good grip on it.
finpos
PostPosted: 23:59 - 06 Aug 2006    Post subject: Reply with quote
Normally the problem is that they are rusted into the bushes or bearings inside the swingarm and are an absolute twatpain to get out, taking days or even weeks of soaking in penetrating fluid plus application of extreme force.
You could try disconnecting the suspension, see if helps at all.
finpos.
GearboxGeezer
Yeah, I always get my dad to help me but hes away at the mo, I havnt got a car jack either, but Ill try and get one, Just wondered if there was another way.
Gradog
PostPosted: 00:04 - 07 Aug 2006    Post subject: Reply with quote
Don't try it without assistance and a support under the engine, you are asking to hurt something or more importntly you if you do try it.
Ask a mate that's what they are there for.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
The last post was made 20 years, 76 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.8 - MySQL Queries: 14 - Page Size: 42.82 Kb
