Gear lever
RickHolt
PostPosted: 10:46 - 13 Apr 2006    Post subject: Gear lever Reply with quote
Got a problem with the gear lever. The teeth on it seem to have worn down and I can't get it to stay on tight very easilly. Obviously the lever is easy to replace, but it looks like the bit it slides onto is more worn. Is that piece easy to replace too?
Also looking for a headlight and headlight mount that will fit a GS500 if anyone has any advice as to what fits.
finpos
PostPosted: 11:55 - 13 Apr 2006    Post subject: Reply with quote
Assuming the gear lever is attached directly to a shaft coming out of the gearbox, you won't get to change that shaft without stripping the engine down.
If you are lucky, just the (softer) metal of the lever will be worn, and the (much harder) gear shaft will be ok. In that's the case just getting a new lever will solve the problem for you.
If you are not adverse to a bit of horendous bodging:
1. Weld it on.
2. Nick some fine needles from the wife/your mum (sorry, sexist comment. Shoot me.). Hammer a few of these in between the gear lever and the gearbox shaft until they snap off flush. Mind your eyes.
Note that if you do either of the above, you may never get the bugger off again.
finpos.
TheDonUK
PostPosted: 15:54 - 11 Aug 2006    Post subject: Reply with quote
I had the same problem untill recently, However my gear shaft and the lever were worn, and as the shaft goes right into the engine, i opted for a bodge.
Was gonna touch some weld on the outide of the gear lever, had no welders around. So we drilled a hole through the shaft AND the lever, and then hammered in a drillbit that was slightly too large (backend of it) and snaped it off... has been holding nicely...
feef
Energiser Bunny
PostPosted: 15:59 - 11 Aug 2006    Post subject: Reply with quote
top bodge for this someone I know did recently..
position the lever on the shaft where you want it.
mark the shaft where the pinch gap is.
dremel a groove on the shaft where that mark is
put a washer on the pinchbot, in that gap such that it sits in the groove, and tighten up.
robert's your aunty's live-in-lover
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
PostPosted: 16:34 - 11 Aug 2006    Post subject: Reply with quote
TheDonUKs one with the drillbit works well.
The last post was made 20 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.34 - MySQL Queries: 14 - Page Size: 44.17 Kb
