what to use to fit a tank cover in place ?
colin1
Captain Safety
PostPosted: 03:29 - 12 Aug 2006    Post subject: what to use to fit a tank cover in place ? Reply with quote
i have a tank cover but dont have anything to stick it onto the tank with
i was thinking of using double sided carpet tape, but im not sure how waterproof it would be and whether it would mark the tank
the tank has been resprayed at some point so i cant be sure i wont rip off paint if i ever need to remove the tank cover
any other suggestions to stick it in place ?
T1z3R
PostPosted: 03:58 - 12 Aug 2006    Post subject: Reply with quote
what make is it?
i thought they usually fitted with straps that went under the tank.
can't you fit some if there aren't any?
duck my sick!
colin1
Captain Safety
PostPosted: 04:32 - 12 Aug 2006    Post subject: Reply with quote
i mean a little rigid carbon fibre thingy
maybe tank cover is the wrong word
do you call it tank protector ?
T1z3R
PostPosted: 04:35 - 12 Aug 2006    Post subject: Reply with quote
ah right, sorry got you now.
id bin it and buy one with adhesive on the back Thumbs Up
duck my sick!
colin1
Captain Safety
PostPosted: 04:40 - 12 Aug 2006    Post subject: Reply with quote
im not doing that, ok next person with another suggestion pls
Sephiroth
PostPosted: 07:50 - 12 Aug 2006    Post subject: Reply with quote
Hot glue gun.
Finglonga
PostPosted: 11:13 - 12 Aug 2006    Post subject: Reply with quote
B&Q double sided pads, Whatever you use you risk draging paint off when you remove it.........Simple solution.......Once its on leave it on.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 13:14 - 12 Aug 2006    Post subject: Reply with quote
Sticky backed velcro FTW.
Bezzer
PostPosted: 15:49 - 12 Aug 2006    Post subject: Reply with quote
Silicone sealant will hold it fine, waterproof, and won't damage the paintwork when/if you come to get it off.
colin1
Captain Safety
PostPosted: 17:08 - 12 Aug 2006    Post subject: Reply with quote
that silcone sealant sounds good
where do i get it ?
is this the same as bathroom sealant, the white stuff you use around baths ?
if thats the stuff, i have some which is handy, i just need to find where the plunger wotsit is
great idea
Handsome
PostPosted: 17:11 - 12 Aug 2006    Post subject: Reply with quote
Yes, but use the Clear Obviously.....
colin1
Captain Safety
PostPosted: 17:21 - 12 Aug 2006    Post subject: Reply with quote
where do i get clear silcone sealant ?
i have only seen the white stuff
Handsome
PostPosted: 17:33 - 12 Aug 2006    Post subject: Reply with quote
Same place you'd get the White from, B&Q or a local DIY store or Plumbers.....Should be easy enough around Dudley Colin.....
colin1
Captain Safety
PostPosted: 17:37 - 12 Aug 2006    Post subject: Reply with quote
thanks
Handsome
PostPosted: 17:44 - 12 Aug 2006    Post subject: Reply with quote
NP.....
Oh and the Gun should only be about 2/3 quid if that.....
colin1
Captain Safety
PostPosted: 18:04 - 12 Aug 2006    Post subject: Reply with quote
i already have the gun, just cant remember where i put it.
PostPosted: 18:28 - 12 Aug 2006    Post subject: Reply with quote
Silicone sealant releases acaetic acid as it cures.
Bezzer
PostPosted: 21:08 - 12 Aug 2006    Post subject: Reply with quote
It does but not in enough quantity to damage anything. I've used it for donkeys years for numerous things, paintwork, plastics,metals etc and never seen any kind of damage using it. Has anyone else?
PostPosted: 23:22 - 12 Aug 2006    Post subject: Reply with quote
I doesn't do much good if you try to seal electronic componants with it.
Gradog
PostPosted: 23:48 - 12 Aug 2006    Post subject: Reply with quote
True, but as a way of sticking carbon fibre to the tank it is probably the best solution. Sticky pads would leave a gap underneath and double sided tape probably won't hold.
Has a great smell as it goes off too.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
krebsy
PostPosted: 14:59 - 14 Aug 2006    Post subject: Reply with quote
I stuck my Divvy's starter relay back together with white bathroom sealant to waterproof it all. Has been fine since then... Smile
K.
What's my New Year's resolution?
1280 x 1024.
The last post was made 20 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 101.85 Kb
