How to bleed a coolant system? + Some other questions
5v3d3b0
PostPosted: 20:33 - 30 Sep 2006    Post subject: How to bleed a coolant system? + Some other questions Reply with quote
I need to fill my coolant system and bleed it...How do i do this? Also, when I removed my cylinder to replace it(havent put the other one on) the sheared cylinder was fillend to the top with compressed coolant which came gushing out the top when I took a bolt off...Ive got the Yamaha TZR 50 (2005).
Also: How do I attach the choke to the carburetor? My last carb didnt have a choke, it has like a switch... Ill provide pics tomorrow if necessary
PostPosted: 02:59 - 01 Oct 2006    Post subject: Reply with quote
Could you repost that with regard to the following diagram. It is a trifle confusing.
Where exactly did the water come out?
What exactly was broken?
It sounds like something fairly serious happened to your engine. It also sounds from your description like it was badly fluid-locked, in which case it may not be as simple as just replacing the top-end.
A more detailed description would be helpful.
5v3d3b0
PostPosted: 18:48 - 01 Oct 2006    Post subject: Reply with quote
Well, I was riding, and i felt the engine shear. It had already happened once, so I immediately knew it was sheared. When I started taking it apart, I just uncrewed the bolts on the cylinder head and there was a big hexagonal screw with some kind of gasket around it which I unscrewed, and when I removed it coolant (I think) came gushing out. I then took off the cylinder and the piston (deeply scratched) and my piston ring is loose.
PostPosted: 20:04 - 01 Oct 2006    Post subject: Reply with quote
No sheared, SEIZED. Laughing
Something that has sheared would have snapped in two. Something that has seized would be stuck.
When you said you'd sheared the cylinder, I though you had cracked the liner of the barrel which could have lead to more serious problems.
So there was no coolant in the actual barrel? (over the top of the piston?)
A simple seizure, you should be able to get the barrel reconditioned providing it isn't too deeply scored. They are probably nikosil plated so this can be pretty expensive. Then it is a case of fitting a new piston kit and putting it all back together again with new gaskets.
As to filling the coolant system. If it is like any normal bike. You take the radiator filler cap off and fill it to the brim with coolant. Replace the cap and top-up the expansion bottle to between the max and min lines. You then run the engine for a few minutes to remove any air bubbles, top it up again and you're done.
5v3d3b0
PostPosted: 20:30 - 01 Oct 2006    Post subject: Reply with quote
The thing is Im selling it, so im changing it back to original parts... What do I use to stick the the cylinder head together with the barrel?
What two caps are you talking about? Here are pics of what I think you mean.
jay_666
PostPosted: 23:08 - 01 Oct 2006    Post subject: Reply with quote
i think your're supposed to re-fill coolant through the radiator cap.
Paddy Blake
PostPosted: 23:15 - 01 Oct 2006    Post subject: Reply with quote
When you are putting the head back on you just need to put the gaskit
on and bolt the head down.
5v3d3b0
PostPosted: 23:23 - 01 Oct 2006    Post subject: Reply with quote
Ok thanks alot guys. So the coolant goes into the cap on the second photo I posted? And the cylinder is held together with the barrel with gasket? Right?
PostPosted: 00:23 - 02 Oct 2006    Post subject: Reply with quote
Correctomundo.
Remember the mating surfaces need to be perfectly clean and level (and free of scratches, dinnae clean them with a wire brush like I've seen some people do!) Gently scrape any muck off the mating surfaces using a bit of flattened copper pipe, being very careful not to mark the alloy then wash in solvent.
You will need a paper gasket to go between the crankcases and the barrel. You will need a head gasket of some sort for under the cylinder head, not sure what it is made of on one of these (think it may be a rubber o-ring).
You will need a torque wrench to put the head on and the sequence you tighten the bolts in is important if you don't want to warp the head.
cagiva gezzer
PostPosted: 00:38 - 02 Oct 2006    Post subject: Reply with quote
Now, while we've got a few minds here.
That coolant expansion bottle. Please convice me it's worth having. My manual says i should have it 1/3-1/2 full. It connects onto the filler neck above the pressuirised valve of the filler cap.
How the hell will any coolant in this bottle back feed into the system (past the one way valve).
The only purpose they serve is to catch over flow from overheating or HG failure, so why the "low" line?
Or am i looking at this in the wrong way?
5v3d3b0
PostPosted: 00:56 - 02 Oct 2006    Post subject: Reply with quote
The sequence being? And what exactly is a torque wrench? Im very new to mechanics....Thanks
PostPosted: 01:26 - 02 Oct 2006    Post subject: Reply with quote
Ok, enough. I strongly suggest you get help with this.
It is not something that is easy to describe to someone with limited knowledge of mechanical terms over the internet and be sure they know what you mean.
I'm happy to tell you how to fill your coolant but describing to a complete novice how to go about assembling and fitting the top-end on a high performance engine is asking for trouble. Especially when they don't know the names of the parts, the tools to use and how to use them.
I don't want to be responsable for something expensive being broken. I'll happily pop over and stand there while you assemble it, I'll even bring my tools for you to do it with but I doubt you are anywhere near Carlisle.
If you post where in the country you are, someone else might be able to assist. It is a relatively simple job but you do need a certain amount of knowledge.
I started to learn motorcycle maintainance with basic servicing under supervision (my dad as it happens) then progressed to bigger jobs with the assistance of detailed workshop manuals.
As I say, you really need someone to help you with this, even if only for the fact that you need a torque wrench (which are expensive tools) to do this job.
Whosthedaddy
PostPosted: 01:51 - 02 Oct 2006    Post subject: Re: How to bleed a coolant system? + Some other questions Reply with quote
Arrow Follow the hoses down past the radiator and before it enters the water pump there should be a small nipple on the underside of the metal pipe. Use and allen key and drain the old fluid out. Dont do what I did and just start pulling random tubes and hoses off, the water gets everywhere Rolling Eyes
Arrow Tighten the drain nut again and fill via the radiator cap a mixture of water and antifreeze.
Arrow Fill to nearly excess, leave the cap off.
Arrow Start the engine and the water should start to circulate around the cooling system, with the cap off any air bubbles should be able to escape. Run for a minute or 2.
Arrow Whilst the engine is cooling down again, tap the hoses and pipes from the bottom upwards to help distribute any air locls that may be present.
Arrow Start engine again and run for a few more minutes.
Arrow Top up if needed, replace the filler cap and go for a ride. Keep an eye on the temp gauge, if it stays within limits then Thumbs Up If not, try repeating the steps Wink
PostPosted: 02:14 - 02 Oct 2006    Post subject: Reply with quote
I don't really understand either. I wrote a long description of what I THINK happens, then realised it amounted to an essay, so I drew a picture.
I'll stress that this could well be totally wrong.
5v3d3b0
PostPosted: 11:46 - 02 Oct 2006    Post subject: Reply with quote
Ok ok ok. I live in Barcelona, Spain, so I doubt you can help me XD. Anyway, Ill just put the piston on and ask the local mechanic (who I know) to tighten the bolts for me. He'll probably do it for free cause I've spent about 700 quid in their shop so far. The coolant I'll just do by myself. Thanks a bunch everyone
finpos
PostPosted: 12:02 - 02 Oct 2006    Post subject: Reply with quote
cagiva gezzer -
When your engine heats up, The water in the rad heats up and expands, creating pressure. This is good as it stops it from boiling, but at at a certain pressure the valve in the rad cap opens and lets some water out into the expansion tank, to prevent the hoses from blowing off. This is normal - not overheating.
There's another valve in the cap which works the other way round. So as the water cools, it sucks some water back in to the rad from the expansion tank.
So if you look at the levels in the tank with the engine hot/cold, you'll see they are different.
You can run without the tank. just fit a long tube which will spit the expanded coolent out somewhere safe. But now, when the engine cools, it will draw air back in. So, you might find yourself topping up the radiator every time you go out
finpos.
5v3d3b0
PostPosted: 22:21 - 03 Oct 2006    Post subject: Reply with quote
The bastards at the mech want 20 quid just to put the friggin cylinder on! How long would that take a pro mechanic with the other one already off!? It's the piston and a few bolts for gods sake!
The last post was made 19 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 99.21 Kb
