domestic gas related question
T1z3R
PostPosted: 11:36 - 09 Oct 2006    Post subject: domestic gas related question Reply with quote
we wish to remove the gas fire from our living room.
ive been quoted £50 from a local gas company to come in and disconnect the gas from the fire and cap the supply beneath the floor.
they said they will not remove the appliance though.
is this something i can do safely? is there anything else behind the fire which would need removed by a CORGI engineer etc?
i know the pilot light etc is there for our central heating system so not sure what else would be involved.
any help welcomed.
duck my sick!
daz|n00by
The Internet
PostPosted: 11:51 - 09 Oct 2006    Post subject: Reply with quote
sounds like you have a baxi boiler, whichmeans the gas fire is part of the heating system for your hot water which in turn means you have whats called a back boiler behind your gas fire? this will be identifed by having 2 22mm pipes that run somewere out side the chimney breast?
if this is the case then you dont need a corgi registered fitter to remove and cap the back boiler but you will (depending on your diy skill) need a plunber, you will also need a new form of getting hot water.
you can buy new gas fires that use the back boiler system but they are very very exspencive.
sorry i cant be much mor help but my only involment with back boilers was removal and refit for the local council and most of these involved using real coal fires and not gas.
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
T1z3R
PostPosted: 12:08 - 09 Oct 2006    Post subject: Reply with quote
that does sound like what we have Crying or Very sad
we want to take the fire and fireplace away as we dont use it and could do with reclaiming the space.
was hoping it was going to be cheap but cant justify the cost of a new or partial heating system.
thanks though Thumbs Up
duck my sick!
The last post was made 19 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 14 - Page Size: 35.85 Kb
