clutch slip
R1stu
Shrek!
PostPosted: 20:04 - 11 Oct 2006    Post subject: clutch slip Reply with quote
Would wrong/mixture of grades oil cause clutch slipping?
Just that under power the clutch slips slightly before gripping!
means cant pull away very fast. but slow power delivery is fine.
It has a new EBC clutch that was recently fitted.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
PostPosted: 20:28 - 11 Oct 2006    Post subject: Reply with quote
Yes, it can cause it. Thicker oil can cause issues occasionally.
R1stu
Shrek!
PostPosted: 00:50 - 12 Oct 2006    Post subject: Reply with quote
Ill give it an oil and filter change see how it goes. The fella I got it from said when he got the clutch done that it needed to be soaked for a day in oil, so maybe as the oil was low that it needs soaking again?
but I stuck in 15w/40 and not sure what was in there so its a mixture of oils new and 6months old fully synth and semi.
PostPosted: 00:57 - 12 Oct 2006    Post subject: Reply with quote
New plates should be soaked in oil. However not much oil gets on them after that. If dry I would just expect it to be more grabby.
An oil change is cheap and easy.
Worst comes to the worst Yamaha clutches are generally very easy to change the plates on.
The last post was made 20 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.60 Sec - Server Load: 2.24 - MySQL Queries: 14 - Page Size: 41.81 Kb
