Heated Grip question...
Method
PostPosted: 17:13 - 25 Oct 2006    Post subject: Heated Grip question... Reply with quote
Ok ive just got me a set of Oxford Hot Grips which i want to fit.
Basically my battery isnt what it used to be and i want to hook the grips up so that they cant be turned on unless the ignition is on...
That means that someone cant walk past and flick them on so they drain my battery / overheat while im not around...
Is there an easy way of doing this? Maybe earthing it through something else on the bike?
I thought i'd ask here before trying anything because im not the worlds best at electrics and i know theres a lot of electrically minded people on here Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
T1z3R
PostPosted: 17:21 - 25 Oct 2006    Post subject: Reply with quote
cut the positive wire into the ON position of your igniition barrel.
theres other places you could take it from further back on the bike but with the grips being up front then its just as easy doing it that way.
dont forget to fuse them Thumbs Up
duck my sick!
nrml76
PostPosted: 17:23 - 25 Oct 2006    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=76064&highlight=heated+grips
Everyone who lives dies, yet not everyone who dies has lived. We take these risks not to escape life, but to prevent life from escaping us.
sickpup
Old Timer
PostPosted: 17:59 - 25 Oct 2006    Post subject: Reply with quote
As Kickstart says the rear brake light positive is the best place to draw power from via a relay and fuse.
PostPosted: 01:21 - 26 Oct 2006    Post subject: Reply with quote
Yep, rear brake light switch. Might already be a blade connector, but if not might also have its own wires attached so that it you make a mess of it all you have wrecked is a couple of quids worth of switch rather than wrecking the main loom.
Use that feed to trigger a relay, with the relay powered directly from the battery (put a fuse in the circuit).
Virtually no extra load through the stock wiring. Plumb it directly to the loom and you will be putting ~3a of extra load on the electrics which is enough to melt wires.
PostPosted: 02:30 - 26 Oct 2006    Post subject: Reply with quote
Don't do this! You'll overload the ignition wiring. 'cutting into' a wire is really bad practice too, can cause all manner of problems.
Wire them straight from the battery with their own wire and use a fused relay in that wire to switch the supply on and off. Take the 'switching' current from a terminal, don't hack the loom about.
If you have spade terminals, you can get a 'piggyback' terminal that allows you to connect to it with no chopping of wires at all (they cost about 5p each). If you have bullet terminals, cut off the original female terminal and fit a double female one to connect into.
This way the original loom has not been messed with and you can easily disconnect the grips to put them on another bike if you want to without leaving a war-zone behind you.
Gazdaman
I did a trackday!!!
PostPosted: 16:09 - 26 Oct 2006    Post subject: Reply with quote
I've done mine /directly/ off the front brake light switch.
It's also the way the official honda kits do it.
Gaz
vfr800
PostPosted: 20:56 - 26 Oct 2006    Post subject: Reply with quote
I can recommend the rear brake light switch method, you can hide the relay under the seat close to the battery and there's enough cable on the kit to get to the handle bars. Thumbs Up
don't take it easy 'ride it like you stole it'
extreme3d
PostPosted: 00:54 - 31 Oct 2006    Post subject: Reply with quote
Ok, after reading Stinkwheels great post about relays I think I finally understand the things! I hate asking for help without doing some homework first so have drawn this up in paint: Hopefully it's correct?
https://i10.photobucket.com/albums/a129/extreme3d51/wiringdiagramheatedgrips.jpg
sickpup
Old Timer
PostPosted: 01:02 - 31 Oct 2006    Post subject: Reply with quote
Yep thats correct.
extreme3d
PostPosted: 01:04 - 31 Oct 2006    Post subject: Reply with quote
sickpup wrote:
Yep thats correct.
Cheers Thumbs Up
Karma
sickpup
Old Timer
PostPosted: 01:06 - 31 Oct 2006    Post subject: Reply with quote
I normally use ones with an 87A tab so they have twin lives but otherwise the same.
Just means I have a spare switched live to play with.
sickpup
Old Timer
PostPosted: 04:53 - 31 Oct 2006    Post subject: Reply with quote
Gaz
Just thought that just because Honda recommend a way of doing electrics it isn't necessarily a good things considering their well deserved reputation for reg/rec's.
GearboxGeezer
PostPosted: 13:11 - 31 Oct 2006    Post subject: Reply with quote
I did this with neon lights... I was a ped boy OK!
Anyway, I connected my neon lights to my rear tail light, and since I never ride wthiout my lights on they would always be on when it was dark! Yet it never drained the battery Very Happy
Gazdaman
I did a trackday!!!
PostPosted: 16:40 - 31 Oct 2006    Post subject: Reply with quote
Agreed, on their reg/rec front. But my heated grips have worked just fine without the added complication of a relay.
Gaz
T1z3R
PostPosted: 16:49 - 31 Oct 2006    Post subject: Reply with quote
ive seen the error of my ways in hacking looms up Embarassed
will give this a go myself when i get some heated grips for the winter months Thumbs Up
duck my sick!
sickpup
Old Timer
PostPosted: 21:23 - 31 Oct 2006    Post subject: Reply with quote
Gaz
A relay isn't a complication its a safety feature that isolates the bikes loom from the grips. If and when the grips finally short out it won't affect the bike so you will be able to ride home.
PostPosted: 23:19 - 31 Oct 2006    Post subject: Reply with quote
Added to which the grips will pull 3a or so extra. Enough to melt the ignition switch wiring if you are unlucky, and certainly a massive extra load on a wire specced to cope with a 1/2a load for a tail light.
PostPosted: 23:25 - 31 Oct 2006    Post subject: Reply with quote
And yet perversely, the reg/recs they were making in the early 1980s are some of the best on the market. Almost every custom built bike on the road has a superdream reg/rec fitted.
I offered to fit one to my mates VFR 750 for a tenner and a couple of pints after his second reg/rec went tits-up. He preferred instead to fork out £80 for an original replacement (two of which had already failed). There's no helping some people.
irving
PostPosted: 23:35 - 31 Oct 2006    Post subject: Reply with quote
Arrow
kawakid
PostPosted: 00:09 - 14 Nov 2006    Post subject: Reply with quote
Just to clarify this.
It isn't the rear brake light? (Surely this is only live when the foots down).
Its the switch that feeds this, ie from when you put your foot down? (Or am I missing something)
Cheers.
PostPosted: 00:14 - 14 Nov 2006    Post subject: Reply with quote
The rear brake light switch will have a powered feed that is live when the ignition is on, whether the rear brake is pressed or not. Split a wire off from that to trigger the relay.
mr.z
PostPosted: 00:27 - 14 Nov 2006    Post subject: Reply with quote
Another good one is the pilot/parking light, which is completely bloody pointless otherwise (mine runs my gps)
Anyone wanting relays get down to your local car breakers and buy arms full for £1/2 and not the £5 most places will charge.
kawakid
PostPosted: 16:21 - 14 Nov 2006    Post subject: Reply with quote
My quote 2 above was just to say its not the brake light, its the brake light switch.
Pete.
PostPosted: 18:51 - 14 Nov 2006    Post subject: Reply with quote
Well I tapped into the live feed to the left switch cluster which is fed from the block connector by the headstock on the GSXR. This can safely feed the indicators and horn. Assuming the horn draws 1 amp, the indicators 2x21W= 3.5amp so the draw is potentially 4.5 amps or thereabouts, so I reckon I can quite happily pull the 3 or 4 amps for the grips from the loom before the switch and still be safe using the indicators. I stripped the casing off the feed wire near the multi-plug connector and soldered the tail in for the grips, released the pin from the conector block and used heat-shrink sleeve to insulate it. So far it's been 100%.
a.k.a 'Geri'
The last post was made 19 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 130.75 Kb
