Air tools and compressors
Whosthedaddy
PostPosted: 20:44 - 08 Nov 2006    Post subject: Air tools and compressors Reply with quote
May be able to persuade the missus to buy me a compressor for air tools / blasting / cleaning / painting, but are they any good for home use?
Screwfix
Tool Station
£100-150 tops so not the real heavy duty ones, but portable enough to sling in the car and use. The tools and accesories seem real good value compared to the electric / hand held versions.
Value for money or waste of money?
finpos
PostPosted: 20:50 - 08 Nov 2006    Post subject: Reply with quote
For occasional use, the hobby ones are fine. For example, you can happily spray a panel on a car, but you wouldn't want to do the whole thing.
Also, it won't run some of the bigger air tools, like the larger impact wrenches.
finpos.
PostPosted: 21:25 - 08 Nov 2006    Post subject: Reply with quote
I have one with a 5L tank and supposedly capable of 7CFM. That is pretty much the min.
PostPosted: 21:33 - 08 Nov 2006    Post subject: Re: Air tools and compressors Reply with quote
I have the OL231:
https://www.diy-compressors.com/shop/direct-drive-compressors.htm
It was a bit cheaper; when I got it and I actually ordered the smaller model, but they messed up delivery and gave me the bigger at no extra cost.
Runs a 480NM impact wrench fine.
Cillit-BANG
PostPosted: 22:25 - 08 Nov 2006    Post subject: Reply with quote
You need to have a good think as to what tools your actually going to be using. Then once you've decided have a look at their requirements with regards operating pressures, consumption.
I very much suspect that 'buy cheap buy twice' could be a concern. Spending an hour googling info or going to see a specialist may be time well spent. The last thing you want is to spend £100 and end up with a compressor that isn't suitable for the jobs you had in mind.
Whosthedaddy
PostPosted: 22:34 - 08 Nov 2006    Post subject: Reply with quote
Going on G's suggestion, the most basic of ones does nt run much.
https://www.diy-compressors.com/shop/about-compressors.htm#diy
Paddy Blake
PostPosted: 00:48 - 09 Nov 2006    Post subject: Reply with quote
Dont let the missus hear the noise they can make before you buy one. Laughing
By the way i got the sprocket.Works fine. Thumbs Up
Paddy.
The last post was made 19 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.89 - MySQL Queries: 14 - Page Size: 52.97 Kb
