Gas Gas Rebuild
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Nisp
PostPosted: 11:39 - 25 Aug 2012    Post subject: Reply with quote
think you might need bigger washers, just because...
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8253709Medium.jpg
Suzuki TS 70 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984
Ichy
PostPosted: 12:22 - 25 Aug 2012    Post subject: Reply with quote
Thanks for the advice but that is the same size as the OEM washer. There is a very good reason why they are that size, want to guess why?
https://i93.photobucket.com/albums/l41/marki_03/bush.jpg
P.
PostPosted: 13:25 - 25 Aug 2012    Post subject: Reply with quote
Filled with grease? Laughing
Nisp
PostPosted: 16:08 - 25 Aug 2012    Post subject: Reply with quote
so when doing maintenance you dont need to take to nut off? Laughing
Ichy
PostPosted: 17:15 - 25 Aug 2012    Post subject: Reply with quote
The washer diameter is about 2mm bigger than the bush. The bush is 1mm thicker than the dog bone.
Anyway. Going in head first I went for the brakes. As ever the pins were seized. Done now and the pistons are clean and moving nicely.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8253714Medium.jpg
Next was the tank. It took a bit of time to remove the corroded fixing since I didn't want to risk damaging the tank. I epoxied in a brass insert. A bit of a clean and it'll be fine.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8253717Medium.jpg
I finally worked out where the coil fitted, obvious really when you see it in place. Still can't work out where to mount the CDI and I just realised that there isn't a hole for the horn to mount to the frame.
NEXT!!
Ichy
PostPosted: 14:58 - 26 Aug 2012    Post subject: Reply with quote
I ripped the end can apart today. It looks like the actual can will scrub up quite nicely. Not sure what to spray it with once it has all been cleaned? Normal lacquer should be OK shouldn't it?
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8263721Medium.jpg
I'm guessing this needs replacing? Last time I can remember working on a 2 stroke is so far in the past that I haven't got a clue what is good or bad.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8263720Medium.jpg
Any suggestions for stuffing? I don't have any fibreglass lying around so I was considering straw.
daverwheeler
PostPosted: 15:00 - 26 Aug 2012    Post subject: Reply with quote
I would leave the packing out and see how it sounds, it's what I've done with all my 2 strokes.
CHR15
Turbo nutter bastard
PostPosted: 15:02 - 26 Aug 2012    Post subject: Reply with quote
i think ive got a load of left over fibreglass packing if you want to call round mine after work on tuesday.
stevo as b4
PostPosted: 15:10 - 26 Aug 2012    Post subject: Reply with quote
Bet your neighbour's loved you mate! Laughing
Ichy
PostPosted: 15:31 - 26 Aug 2012    Post subject: Reply with quote
Cheers Chris. I'll be in touch Thumbs Up
daverwheeler
PostPosted: 16:42 - 26 Aug 2012    Post subject: Reply with quote
TBH with the bare baffles in they are not too bad. Honest!
Failing that a (not very long lasting) solution is glass fibre loft insulation.
CHR15
PostPosted: 18:50 - 26 Aug 2012    Post subject: Reply with quote
no worries, just dug it out. there's probably just enough to pack that can with.
if your popping round on tuesday, is there any chance i could be cheeky and ask if you've got a rear paddock stand i could borrow for a few days to swap the c+s and rear disk on my new bike?
Ichy
PostPosted: 20:05 - 26 Aug 2012    Post subject: Reply with quote
Sorry I sold the stands when I caught the ghey. I do have axle stands and stuff if it is any use?
2T noobie fail time. Crying or Very sad
I can't get it to run. Well not 100% true but here goes. I've filled all the fluids and filled up the carb with premix through a remote tank (pop bottle). Changed the plug and I definately have a spark. Choke has been tried on and off but it won't even back fire/pop/bang/anything. It will run for a couple of seconds if I spray carb cleaner into the carb. I've cleaned the carb twice, it's a real simple design and I cannot see any blockage.
Does the fact that it will run on carb cleaner mean that the piston timing, reed valves and everything else after the carb is working ok? Am I missing something obvious?
CHR15
PostPosted: 20:11 - 26 Aug 2012    Post subject: Reply with quote
pair of axle stands would be spot on, if you don't mind. i can just sit it on the pegs
HD
PostPosted: 20:13 - 26 Aug 2012    Post subject: Reply with quote
Not sure what type of fuel pump it has but if there are two, have you got the fuel going to fuel and vacuum to vacuum? Jets screwed all the way in? Idle not set too low? Mixture screw set right?
PostPosted: 20:18 - 26 Aug 2012    Post subject: Reply with quote
I have a paddock stand you can borrow for a bit if you want
Ichy
PostPosted: 20:32 - 26 Aug 2012    Post subject: Reply with quote
No fuel pump. I've never run the bike so I'm assuming that the screws are close to where they should be.
Drake
PostPosted: 21:21 - 26 Aug 2012    Post subject: Reply with quote
tried popping some 2t in the plug hole to up compression and help it is fuel getting through the reed valve and into the cases?
woll
PostPosted: 11:58 - 27 Aug 2012    Post subject: Reply with quote
Looking well Mark Thumbs Up
The carb settings should be the same as they've always been. I never fiddled with them. I had a similar problem a time or two. Make sure your getting a good strong blue spark, check that both ends of the ht lead have plenty of good copper there, check the connections to the coil. It was a pain a couple of times the connection to the coil. And check the coil is good. It was replaced not long after i got the bike by blacks.
Give it a kick, then check if the plug is getting wet. If it's not then that points to the carb being wrong. If it is getting wet, then it's possible the compression isn't high enough or spark problems.
I'd give it a try with a small amount of 2t down the bore, to help with compression. If it starts that way keep it running for as long as you can to bed the rings into the bore and up the comp. If that doesn't work it could be possible the crank doesn't have a long enough stroke if you changed it, or that the piston isn't the right size.
The horn IIRC was bolted onto a metal plate that bolted to the coil.
If you need any help give me a ring.
HD
PostPosted: 13:42 - 27 Aug 2012    Post subject: Reply with quote
Can't remember now but did you clean the carb?
CHR15
PostPosted: 13:46 - 27 Aug 2012    Post subject: Reply with quote
https://i939.photobucket.com/albums/ad233/chris-bracey/Megaman_Derp_1754708_2459276.jpg
Ichy
PostPosted: 14:00 - 27 Aug 2012    Post subject: Reply with quote
Thanks for the advice guys, especially Woll.
Karma is a bitch! Many posts ago I typed this
FWIW the carb was as good as could be expected. Nothing needed to be done.
Turns out I was being a bigger noob than I though. I decided to strip and clean the carb for a third time and finally noticed that the needle valve was jammed shut Rolling Eyes No fuel in carb means no starty. Stripped and cleaned the valve and it started on the second kick. I ran it for a minute just to check. Tickover was very steady.
The kickstart was a bit knackered and I didn't want to spend the stupid amount that gasgas want for a new one so I fitted a small steel plate to take up the slack, works well for now.
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8273726Medium.jpg
Spent a bit more time on the end can.
It went from this:
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8273750Medium.jpg
to this:
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8273751Medium.jpg
To this:
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8273753Medium.jpg
in a couple of minutes with the help of these:
https://i93.photobucket.com/albums/l41/marki_03/Gas%20Gas/P8273755Medium.jpg
I love the stuff. A 3m pad and Astonish oven cleaner is one of the best abrasive cleaners I've ever used. Best bit is that the cleaner costs just a quid. Not a lot I can do about the pitting but it should look better once it is fitted.
HD
PostPosted: 19:14 - 27 Aug 2012    Post subject: Reply with quote
1. Fhek.
2. I felt/feel so patronising giving someone like Marki advice when he knows so much more than me Laughing
Drake
PostPosted: 19:56 - 27 Aug 2012    Post subject: Reply with quote
dont then?
The last post was made 11 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Page 5 of 7
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.38 - MySQL Queries: 17 - Page Size: 146.65 Kb
