What? Another VFR
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Tim..
PostPosted: 16:01 - 20 Jul 2012    Post subject: Reply with quote
Cheers Thumbs Up
Got bored of waiting for parts again.
I have an old set of levers that were looking very scruffy so I decided to attack them with the aim of making them lighter and less wind resistant.
The method works for GP bikes so why not mine, that and I was going to throw them away anyway.
Old school cool or stupidly unsafe?
Before
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1210.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1212.jpg
After
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1213.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1216.jpg
www.marshallracing.co.uk
Tim..
PostPosted: 17:51 - 21 Jul 2012    Post subject: Reply with quote
Just noticed - cheers for the unrelated bad karma Watchman Rolling Eyes
Recently won a new secondhand clutch lever and perch off the bay because it looked good in the picture, seller failed to mention it had been through the gravel in the description though. Which made more work for me.
Anyway, all stripped, painted, regreased and bolted up.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1220.jpg
With the nice weather decided to get the temp engine painted.
Before
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1222.jpg
After
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1224.jpg
Also cut the sprocket cover down as per the HRC TT-F3 manual and painted it.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1227.jpg
Prep for when the engine is dry and ready to work on
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1231.jpg
Tim..
PostPosted: 21:40 - 27 Jul 2012    Post subject: Reply with quote
The billet quick action throttle arrived, nice cheap new part and dug out the throttle and clutch cables.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1250.jpg
New grips and guards, didn't want to skimp on these tbh
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1252.jpg
Oil'd, greased, glued and lockwired together
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1254.jpg
Bit more engine prep before it goes into the chassis. Filter, water pipes and bolts with the threads run through with a tap all done.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1255.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1257.jpg
Need to sort out the loom now
Tim..
PostPosted: 19:57 - 31 Jul 2012    Post subject: Reply with quote
Turned this mess into something usable. The Reg Rec plug was chopped off the other loom and wired into this one. Aswell as the whole lot being cleaned and retaped.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1271.jpg
Mounted quite a few bits here, lhs grip glued and lockwired on, rhs switchgear mounted (hole drilled), quick action throttle and clutch cables.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1286.jpg
How the bike sits at the moment with its loom in the correct place.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1287.jpg
Few final parts of the loom to be cleaned and mounted later.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1291.jpg
Need to get a box of parts zinc coated now before I get the engine in.
hazza
PostPosted: 20:15 - 31 Jul 2012    Post subject: Reply with quote
Tim your attention to detail mesmirises me and this is only meant to be a rough vfr out of spares. My only negative comment is i hate those grips! The plain grey renthals would look so much better, sorry...
swiftb
PostPosted: 20:18 - 31 Jul 2012    Post subject: Reply with quote
fellow hater of the grips here. Plain ftw. Looking good otherwise Thumbs Up
Frost
PostPosted: 20:19 - 31 Jul 2012    Post subject: Reply with quote
They do look chav-tastic as fuck. But i recall from the previous thread that they have a protective sticker over them that makes them look like that. When removed they're grey.
swiftb
PostPosted: 20:28 - 31 Jul 2012    Post subject: Reply with quote
ah yes i see now after looking at the other pics. They are just protective covers. Thought they were the turd clear grips with the gsxr/r6/renthal etc inserts which are gaf. Phew.
Tim..
PostPosted: 22:09 - 31 Jul 2012    Post subject: Reply with quote
Ah the grip protectors strike again. They are indeed plain (mediums)
Tim..
PostPosted: 17:17 - 17 Aug 2012    Post subject: Reply with quote
Was sick of looking at the manky rear shock and I managed to get (rather cheaply) a BMW s1000rr rear shock and RVF lower linkages to raise the ride height.
Wonder what suspension properties cardboard has Very Happy
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1352.jpg
Both together.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1349.jpg
So far I have had to skim the top of the bmw shock to 38.4mm across to fit the chassis and change to a 800lbs spring. The guys at HM Racing have said to me it'll definately need revalving as the rebound isnt great from the factory but also said to set the sag before spending any money with them.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1355.jpg
Will hopefully have it in the bike at the weekend and will report back any more mods that were needed.
Tim..
PostPosted: 23:15 - 17 Aug 2012    Post subject: Reply with quote
Ok well I got the shock in tonight.
All that was needed was to file the frame back slightly on the back of the undertray mount. 3mm approx.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1359.jpg
All torqued up with one half of the RVF linkage, waiting on the other half to come back from zinc coating.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1361.jpg
After reading through the BMW riders manual Ive set it to normal riding for the compression and to hard race on the rebound to compensate for the valving. Will do as a starting point.
Tim..
PostPosted: 20:43 - 22 Aug 2012    Post subject: Reply with quote
Hit another problem, this time with the shorter RVF linkages.
With the wider spring, it fouls on the swingarm, not even allowing me to get all the linkage bolts in.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1373.jpg
So this bike will be running all VFR lower linkages.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1374.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1375.jpg
Also did a bit more work to the engine with all the zinc'd parts back. Will get some pics when all bolted up.
Tim..
PostPosted: 16:59 - 23 Aug 2012    Post subject: Reply with quote
Got some work done to the engine, cheeky bar steward who sold me the engine snapped on of the exhaust studs and swapped it round. So of course it was too short. Luckly I had a spare stud set and gaskets which allowed me to get the manifold on.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1376.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1378.jpg
Just waiting on a few more bits and it can go in the rolling chassis.
Maruchino
PostPosted: 18:15 - 23 Aug 2012    Post subject: Reply with quote
There is no bloody way you would catch me riding a bike with after-market holes drilled through the brake lever!!
though nice work again, so far Smile
Tim..
PostPosted: 21:00 - 23 Aug 2012    Post subject: Reply with quote
Want to figure out a way of testing them off the bike really.
I have another set of levers that can be used.
Tim..
PostPosted: 22:03 - 26 Aug 2012    Post subject: Reply with quote
With the better half away for the night I got some more garage time in. A friend from 400GB kindly donated two fooked undertrays to me, with my intention being to make one good one. Also to lose some of the un-needed plastic.
Started off like this.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1387.jpg
Ended up like this. The bike will be on a daytime MOT, which is why I have kept the number plate mount. Kept the rear reflector for the lols as they always seem to get cut off.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1396.jpg
Had some left over reflective material so used it to replace the rotten one that covers the battery box.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1394.jpg
All cleaned and fitted to the bike, just missing one bolt which I cant find atm.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1400.jpg
Frost
PostPosted: 15:06 - 27 Aug 2012    Post subject: Reply with quote
....so....
Which one were you planning to fuel inject?
Tim..
PostPosted: 17:23 - 30 Aug 2012    Post subject: Reply with quote
Maybe this one at some point, no plans for it any time soon though
Pulled some more spares out and wired up the ECU and de-restriction box.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1409.jpg
et1
PostPosted: 08:26 - 31 Aug 2012    Post subject: Reply with quote
Very interesting! Like these full attention to detail projects! Keep up the good work! Thumbs Up
Tim..
PostPosted: 13:42 - 06 Sep 2012    Post subject: Reply with quote
Cheers Thumbs Up
Bought a Tyga RCV front fender a while ago for my other bike. Having no use for it now I asked Gavin at Jap4 if it could be swapped it for a carbon nc30 one, and he kindly said yes if a bought something. So I ordered up a new clear screen (something I don't have) for this bike and a new can for my other project.
Also been collecting graphics and stickers for ages, should be able to decent TT scheme from this lot.
https://i475.photobucket.com/albums/rr119/Timon1983/Honda%20VFR%20Race%20fairing/IMG_1439.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/Honda%20VFR%20Race%20fairing/IMG_1436.jpg
And then I found more!
https://i475.photobucket.com/albums/rr119/Timon1983/Honda%20VFR%20Race%20fairing/IMG_1443.jpg
Also ordered a new number plate as the chassis only came with the logbook.
Tim..
PostPosted: 17:59 - 06 Sep 2012    Post subject: Reply with quote
Also checked all the charging system is working correctly, no open or short circuits. Checked the coils are OK to use and that the wires on the loom for the regrec have good continuity.
All cleaned and fitted.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1451.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_1447.jpg
naf456
PostPosted: 09:29 - 07 Sep 2012    Post subject: Reply with quote
I've always wondered how to paint things properly.
I see you have painted you engine matte black - did you just spray it directly, or did you prime it first?
I worked on customizing a PC case - primed the chassis and sprayed it matte black , but the paint just came off with a hard rub.
very annoying. Neutral
I Don't Suffer From Insanity - I Enjoy Every Minutes Of It.
matto
PostPosted: 20:15 - 08 Sep 2012    Post subject: Reply with quote
Tim.. wrote:
Cheers Thumbs Up
Before
After
I'ver read your other thread and am generally quite impressed but I'm not sure they're very safe, shouldn't the holes be drilled through in the opposite plane to the force exerted to maintain the strength? Like these https://t1.gstatic.com/images?q=tbn:ANd9GcS_iu750np4GrEkMtdecLBhQuhtnfuO0YpYOZ7pgiY-3q2hBLvyibXWrWu34Q
Tim..
PostPosted: 20:19 - 09 Sep 2012    Post subject: Reply with quote
The idea was to let the air pass through them so as not to cause any drag that could pull the lever in, mainly because the bike is capable of warp like speeds Wink . I weighed them mainly out of interest.
Going to try and rig up a jig to see what the maximum force I can extert through my hand, double it and see if the lever can withstand it.
Normal levers will break in a crash situation so am not worried about that.
Frost
PostPosted: 21:12 - 09 Sep 2012    Post subject: Reply with quote
https://www.kurveygirl.com/Brembo/KG%20-%20Brembo%20-%20MotoGP%20Lever%20-%20RCS%20-%20Master%20-%20800_wm.jpg
That's what they do in MotoGP to stop the 215mph wind from putting the front brake on.
You won't snap the levers by hand even putting all your strength into them, but in a crash they will snap and could then stab into you. That's why they have the bobble on the end.
The last post was made 11 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 9
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 149.51 Kb
