Author |
Ichy |
Ichy World Chat Champion
Back to top |
Xenocide |
Xenocide Scooby Slapper
Back to top |
nowhere.elysium |
nowhere.elysium The Pork Lord
Posted: 11:02 - 17 Jan 2013 Post subject: |
Ok, in order of posting:
Kramdra - Yes, a larger one probably could do fairings, although they'd be fairly heavy.
Blurredman - The plastic's fairly strong; I believe it's classed as an engineering plastic, and makes surprisingly durable rigid structures.
Marki - that's a fine offer; I may well give you a shout in the not-too-distant future. As to the 3D scanner, I keep thinking that I should design my own. The real problem that I'd have would be in designing the hardware to interpolate a stereoscopic video stream. I certainly don't have the money for an off-the-shelf unit, aside from the Kinect, maybe. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
Fawbish |
Fawbish World Chat Champion
Back to top |
oldpink |
oldpink World Chat Champion
Back to top |
nowhere.elysium |
Posted: 09:16 - 31 Jan 2013 Post subject: |
oldpink wrote: | bump
nowhere.elysium you are a cu*t | Yes. Yes I am.
oldpink wrote: | can I ask a few quick questions
if you scaled it up to 50 or 100% bigger would that dramatically effect the accuracy req to calibrate it
being the further it has to move the greater chance of error
or is there a fixed size that you have to stay within | Not really; the precision is determined by the motor's step size, as well as how well you assembled the printer initially. A larger print size only means more steps, not bigger steps, so you should still have similar precision.
oldpink wrote: | having seen a lot of the code you have posted regarding setting parameters, it seems very similar to PHP and other coding (hashing out irrelevant parts and manipulating variables)
I also used C and C+ back in pre historic days when I was program debugging | Yes, it's C++ - the only real guidelines are to try and keep it simple; minimise floating-point stuff, be pernickety about how much RAM you're using, that sort of thing.
oldpink wrote: | is it hard to pick up the software and control systems with some basic background knowledge in electronics's and components
I did a degree in radio electronics's many moons ago and can use a soldering iron and know what a test meter is for and how to use it | Well, to lend a little context, I have an Art degree - my only associative background with this is having worked in IT support for years, and having a voracious sense of curiosity.
oldpink wrote: | P.S. what happened to the secret project ?? | 'Tis a mystery. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
Aff |
Aff World Chat Champion
Back to top |
nowhere.elysium |
Back to top |
Aff |
Back to top |
nowhere.elysium |
Back to top |
nowhere.elysium |
Back to top |
CHR15 |
CHR15 Turbo nutter bastard
Posted: 22:10 - 14 May 2013 Post subject: |
have you started printing guns yet? ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
Back to top |
nowhere.elysium |
Back to top |
orac |
orac World Chat Champion
Back to top |
Ichy |
Posted: 11:14 - 15 May 2013 Post subject: |
For large machines I'd go for linear scale tape and encoders. Accuracy would be very good, 10 µm/m being a fairly low resolution. The largest measurement machine we have at the moment is around 17 meters and real world errors are around 0.2mm from one end to the other. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
Back to top |
There is a gap of 203 days between these two posts... |
nowhere.elysium |
Posted: 18:31 - 04 Dec 2013 Post subject: |
Oh dear. I've just had to change over the hot end, because it burned out a couple of weeks ago, and decided to upgrade the firmware while I was at it.
Big mistake.
Looks like the firmware's been very actively developed in the intervening year since I last looked at the released versions. As such, I'm swearing at the (now significantly larger) firmware, trying to get it all to behave itself. So far, things I've had to complain at:
inverted motor directions,
inverted endstop responses,
incorrect stepping values,
totally insane heating speeds.
This list may grow. Either way, there's been one good spinoff from the insane heating speeds; the PID process in the new firmware has been massively improved, so after only two updates, I managed to get some good PID values in there, and it's now nice and stable when heated. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
serlant |
serlant Brolly Dolly
Back to top |
Fawbish |
Posted: 16:50 - 24 Jun 2014 Post subject: |
So I'm very close to pushing the button on this -
https://reprappro.com/shop/machine-kits/mendel-full-kit/
and starting my own little journey into discovery of hair tearing innovation.
Any major hints and tips nowhere?
thinking I should just dive in to be honest! ____________________ "Oh....it looks like Average Joe's is forfeiting the match!" - "Yeah, its a risky strategy but lets see if it pays off for 'em Cotton." |
Back to top |
nowhere.elysium |
Posted: 19:38 - 24 Jun 2014 Post subject: |
1) Do it, Faggot.
2) Be methodical, patient and precise. This is often best served by taking photos of what you're doing at every stage, for future reference.
3) Get friendly with the Arduino environment. You will find yourself re-uploading firmware multiple times, in the quest for perfect performance.
Give me a shout if you feel the need. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
Aff |
Back to top |
nowhere.elysium |
Back to top |
There is a gap of 224 days between these two posts... |
Aff |
Back to top |
nowhere.elysium |
Back to top |
Aff |
Back to top |
nowhere.elysium |
Back to top |
The last post was made 9 years, 128 days ago. Instead of replying here, would creating a new thread be more useful? |
