Downshifting technique
loply
PostPosted: 13:56 - 27 Apr 2016    Post subject: Downshifting technique Reply with quote
Hi folks,
Just looking for some advice on shifting down on track.
I've been trackdaying/racing an SV650 the last 2 years and it's something I've struggled with. I'm going fairly well with middle of the pack laptimes at club meetings.
I always was taught to blip the throttle and release the clutch between every gear, so if I'm going down 3 gears I'll quickly do this three times:-
• Pull clutch lever
• Blip throttle
• Hit gear lever
• Release clutch lever
[Repeat x2 more times]
It sounds longwinded but in reality you can do it quickly... but I'm finding when I go faster this takes too much concentration and can cause me to very the brake lever pressure when I rotate the throttle tube, meaning I only get 'full' braking after I've finished shifting. If I go in too hot I end up struggling to get it all done in time.
What does everybody else do? I'm thinking about learning to just hold the clutch in, drop all 3 gears then release the clutch smoothly with some throttle... It's hard to change habbits though.
No slipper clutch fitted. I do sometimes get a squirmy rear end going on but not too bad usually.
Would appreciate any comments.
Yamaha SZR660 Caution to the wind, the throttle pinned!
recman
PostPosted: 15:54 - 27 Apr 2016    Post subject: Reply with quote
Are you consciously performing a four stage process every time you change down?
I usually clutch in, downshift while giving it a flick of throttle at the same time then clutch out.
I've not been on a track though.
Old Git Racing
PostPosted: 21:26 - 27 Apr 2016    Post subject: Reply with quote
Example - On Park Straight at Cadwell. 6th gear, pull clutch in at your braking point, bang it down 4 gears to 2nd as quick as you can blipping with each change. Let clutch out carefully,i.e. don't just let it go unless you are Sam Lowes and have a slipper clutch. Bet you if you do this your braking point will be less.
If you're trying to do good times on a trackday or racing you have to be aggressive, its not the road coming up to a pelican crossing.
Word of caution, you're doing quite a lot of things here at the same time - getting the braking a late ass poss, banging it down the right number of gears, blipping whilst braking and just keeping the back wheel hovering off the road, remembering to not just let the clutch go, making sure you do the line and the apex, being aware of other nutters coming up the inside who are either better or worse than you at this.
It's not as easy as many think to get it just right, The ones who do it without mistakes every corner lap after lap win or are the fastest.
OGR
loply
PostPosted: 23:15 - 27 Apr 2016    Post subject: Reply with quote
Old Git, so are you saying you hold the clutch lever in for the whole time, only releasing it once you reach the final gear?
Yet you still blip the throttle for every gear you go down?
Pjay
PostPosted: 23:46 - 27 Apr 2016    Post subject: Reply with quote
I'd brake down hard if dropping a few gears and just throttle up before releasing the clutch.
Doing it through each gear would be shifting the centre of gravity about too many times for my liking.
.Bishbash.
PostPosted: 23:51 - 27 Apr 2016    Post subject: Reply with quote
No, that would be pointless. You'd need to release the clutch quickly, but not dumping it. If you don't have a slipper clutch, then you need to blip and release, to assist with braking and get it in the right gear. If you have a slipper clutch, like I do, then ease the clutch out after every change but at fast pace to do the same.
I tried both scenarios with a slipper clutch and to save my brain I take the second option and it works.
Current bike - GSX-R1000 k8
Old Git Racing
PostPosted: 19:50 - 28 Apr 2016    Post subject: Reply with quote
Yes I'm saying hold the clutch in and drop 4 gears blipping it. There is a certain amount of drag even with the clutch in so you need to blip it, makes the gears go in easier.
If you're doing it right you don't have time to let the clutch out with every down change.
Go on you tube and find some races from Mallory going up to the hairpin, particularly 2 strokes, 5 rapid fire blips from top to bottom gear, clutch in.
OGR
.Bishbash.
PostPosted: 07:25 - 29 Apr 2016    Post subject: Reply with quote
I have never heard that technique before, certainly haven't tried it. Is this specific to V-Twins, or all bikes?
loply
PostPosted: 14:08 - 29 Apr 2016    Post subject: Reply with quote
Thanks old git, I'll probably give that a try next time. Something to think about.
TbirdX
PostPosted: 14:53 - 29 Apr 2016    Post subject: Reply with quote
2 stroke motocross method...
throttle full open...brake,throttle full closed, clutch in, stamp down gears until you hit the right gear for exit speed, when exit speed reached, dump clutch and throttle full open.
Mechanical sympathy not a big thing in motocross Smile
VFR800X - TTR250
.Bishbash.
PostPosted: 21:29 - 29 Apr 2016    Post subject: Reply with quote
Seriously, someone please tell me how that even makes sense....Educate immediately
PostPosted: 22:14 - 29 Apr 2016    Post subject: Reply with quote
I haven't used it, but it makes sense - removes all engine braking issues.
At maximum braking with the front brake, the rear wheel should be very light - just about to lift. At this point, the rear shouldn't have the capability to do any significant braking by friction - though presumably having the rear wheel slowed by the engine rather than the road could be beneficial.
Generally; it is common to gear down too early, which unsettles the bike more. However of course you don't want to leave it so late it causes problems turning in.
I have tried in the past
My favourite braking moment on track was still on an SV at lydden - I obviously didn't manage to keep the brake modulated quite right as I did a mini stoppy as I went down a gear.
Which worked quite nicely, as the rear wasn't in contact with the ground while down shifting and the whole process was quite smooth.
Blue_SV650S
PostPosted: 10:18 - 30 Apr 2016    Post subject: Reply with quote
On a 2-smoke MX there isn't really any engine breaking to be had/make advantage of, so taking it out of the equation totally makes sense.
As for on the track with a large 4t, then one should be on the power until the instant of hitting the brakes for a corner. Then frantic clutch in banging down the box with a blip and some slippage/partial engage for each gear.
Balance the throttle if long sweeper, back on the gas and 'squirt' out if not.
Job done!
The last post was made 8 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.45 - MySQL Queries: 15 - Page Size: 77.53 Kb
