CHR15 |
CHR15 Turbo nutter bastard
Blau Zedong |
Blau Zedong Banned
Posted: 10:09 - 27 Aug 2012 Post subject: |
I think "Pulse Corn" did a system too
Those crazy nips! ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth |
CHR15 |
Nope. |
Nope. World Chat Champion
CHR15 |
Posted: 15:40 - 30 Aug 2012 Post subject: |
well, today started off good, then went rapidly down hill.
i passed my car test. yaay.
then lots of stuff in suzuki bags arrived. also yaay.
then i took the sump off and it was full of copper slivers and rtv. not so yaay.
so, looks like the engines gonna need a complete rebuild over winter. i just hope suzuki still make all the shell bearings.
also, theres pitting on one of the gears on the output shaft.
thing is, it sounded okay when i fired it up last week...
think i'm gonna buy breakdown cover lol.
only thing i've managed to do today is foil the tank:
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash4/294580_10151031191238365_1786169156_n.jpg
guess you cant own a 24 year old sports bike and not expect it to be a bit shagged. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
chris-red |
CHR15 |
Posted: 15:56 - 30 Aug 2012 Post subject: |
there not loose in that direction, if you grab hold of them from side on, you can rotate them clockwise / counter clockwise by almost 25mm from extreme to extreme. ____________________ Turbocharged drag thing / project death weapon / GK73A
Blau Zedong |
Blau Zedong Banned
P. |
P. Red Rocket
Posted: 17:55 - 30 Aug 2012 Post subject: |
inb4 my engine died lol thread
He has a point though, if it runs and goes well... shows good compression and gives you the buzz... |
CHR15 |
MarJay |
MarJay But it's British!
Tim.. |
Tim.. World Chat Champion
chris-red |
CHR15 |
Posted: 19:56 - 30 Aug 2012 Post subject: |
Only gasket I may need is a sump one which is £10.73 iirc.
Can split the bottom end without taking the top off. ____________________ Turbocharged drag thing / project death weapon / GK73A
orac |
orac World Chat Champion
CHR15 |
Posted: 20:21 - 30 Aug 2012 Post subject: |
How can I do the mains without removing the crank? Lol ____________________ Turbocharged drag thing / project death weapon / GK73A
orac |
CHR15 |
Posted: 22:06 - 30 Aug 2012 Post subject: |
if its coming to bits, its gonna be done proper.
i'll have the crank checked for straightness, get the rods balanced end to end, and to the crank and weight match the pistons.
for the sake of 200 quid its false economy not to replace all the bearings and rod bolts. ____________________ Turbocharged drag thing / project death weapon / GK73A
Pete. |
Pete. Super Spammer
orac |
Posted: 00:23 - 31 Aug 2012 Post subject: |
i take you you either get more trade discount than me on suzuki parts, or your not going genuine - the last time i ordered bearing shells, it was nearly 160 quid just for main alone.
full gasket set should be around £100, then if we say £200 for mains, big end, all new bolts (main bearing bolts should be replaced once removed) new gearbox bearings (just as well why you are there), then around £50 for a new timing chain plus the cost of having things balanced.
then if we presume that you going to do valve stem seals and giuds too - jsut as well seeing as its all coming apart, 16 at around £2.30 each for the seals, then the wait for delivery from japan for anything that isnt in the UK or even europe.
oh and nearly forget the stupid money suzuki want for the gearbox seals - specialy the one that like to leak - you know the one with the clutch push rod that run through it. all in all its gonna be more like 400-500 quid to do it all if that the way you want to go.
if i had the sort of money that you have been spending on bike, i would chuck the thing back together and sell it to some other sucker - heck if i had 500 quid to spend on a bike, with a little return on my current machine (which is next to worthless atm) i wold by buying another machine instead of taking the risk of an unknown engine.
but that i said, i would split the bottom end before making a final desicion, the the crank looks OK, then chuck some new bearing shells in, check the oil way chuck it back together and thrash within an inch of its life - then start a fresh ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
Pete. |
Pete. Super Spammer
Posted: 01:22 - 31 Aug 2012 Post subject: |
'85 GSXR750 is £850 a pop for mains, £11-ish for big ends, genuine parts. Can't find prices for this bike but I know that a full set of both for a 'busa was less than £200 last time I bought.
Rod bolts I would re-use. There should be a stretch figure for installing them, I guess you could find that out and stick a MIC across them. I'd just re-use them anyway, and make sure you sue anti-seize under the head if you're doing them up to a particular torque. ____________________ a.k.a 'Geri'
CHR15 |
Ichy |
Ichy World Chat Champion
P. |
P. Red Rocket
Posted: 09:15 - 31 Aug 2012 Post subject: |
I'm not sure if I'm upset you have a car licence...or these tears are from the thoughts of this supreme turbo kit car you are going to build |
orac |
The last post was made 11 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
