CHR15 |
CHR15 Turbo nutter bastard
Posted: 19:18 - 17 Mar 2013 Post subject: |
did think that, but there's a lot of things that could go wrong.
ive had an idea in the mean time. whilst im waiting for bits for the roller starter.
if i get an old front sprocket and weld a piece of 1/2 hex bar to it, i can spin the engine over via the front sprocket using this bad ass wrist breaking 110v drill we've got at work. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
Howling Terror |
Howling Terror Super Spammer
Kickstart |
Kickstart The Oracle
suzukirider19... |
suzukirider19... Nova Slayer
CHR15 |
Posted: 21:57 - 17 Mar 2013 Post subject: |
Yeah. It does go and when I actually got it going it revved and sounded fine.
The thing that's niggling me is that the spark isn't as good as I think it should be. It's blue, but its quite a thin spark, not a fat loud one.
My '68 bantam had a much stronger spark and that was running all the origional parts when I first got it going.
But all the resistances check out... ____________________ Turbocharged drag thing / project death weapon / GK73A
suzukirider19... |
CHR15 |
Posted: 22:15 - 17 Mar 2013 Post subject: |
its had 3 new plugs.
started with the recommended platinum plug
swapped to an iridium plug
now using a bog standard br8es
tried fuel down the bore, tried preheating the plug, tried easy start, tried leaving it for ages to air out the crankcase, tried full throttle / no throttle / choke / no choke, tried taking it to tdc and giving it a swift kick with my body weight, tried thrashing it like im stamping on justin beibers head, tried bump starting.
only thing left is to just spin and spin and spin and see what happens.
also ordered a new pair of petals but there on back order from suzuki. ____________________ Turbocharged drag thing / project death weapon / GK73A
suzukirider19... |
CHR15 |
Posted: 23:45 - 17 Mar 2013 Post subject: |
cover the carb and it pisses fuel out the overflow and airjet hole. ____________________ Turbocharged drag thing / project death weapon / GK73A
suzukirider19... |
kramdra |
kramdra World Chat Champion
Posted: 23:58 - 17 Mar 2013 Post subject: |
disapoint.
several people push/ bump start? with video ofcourse. |
CHR15 |
TotalGSXR |
TotalGSXR Borekit Bruiser
CHR15 |
Posted: 10:48 - 18 Mar 2013 Post subject: |
did fitting oem reeds cure the problem? ____________________ Turbocharged drag thing / project death weapon / GK73A
nightshaddow |
nightshaddow Nearly there...
Posted: 12:27 - 18 Mar 2013 Post subject: |
sounds daft being an rm engine but have you tryed adding a power source to boost up the electrics
some bikes need a small amount of power just to get going ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
TotalGSXR |
stevo as b4 |
Posted: 19:28 - 18 Mar 2013 Post subject: |
It's a omen pure and simple! The bike is the devil and it's trying to warn you not to mess with it, as if you do persist enough to unleash the fury within, it's going to seriously kill everyone who's ever seen it and rip out the heart from every corpse! |
CHR15 |
CHR15 |
Posted: 20:22 - 18 Mar 2013 Post subject: |
anyway, today i tried the drill on the front sprocket idea.
it stalled the drill when it hit compression in 5th gear.
not sure if engine is trolling or just 93:1 cr.
i tried it without a spark plug and it turns over fine.
the threshold point for sparking is about 250 crank rpm, with a nice spark by 300.
which means in 3rd gear, my 2" starter rollers need to do 450 rpm to get the crank doing 300.
i also worked out the speed and ratios. at 8k rpm in 3rd the bike will be doing 60mph.
i think thats probably why its so hard to bump start. ____________________ Turbocharged drag thing / project death weapon / GK73A
The999Kid |
The999Kid World Chat Champion
Posted: 02:38 - 19 Mar 2013 Post subject: |
SQL |
SQL World Chat Champion
CHR15 |
P. |
P. Red Rocket
Posted: 09:38 - 26 Mar 2013 Post subject: |
Direct as fuck |
Alpha-9 |
Alpha-9 Super Spammer
SQL |
Posted: 17:14 - 26 Mar 2013 Post subject: |
Don't beat around the bush |
The last post was made 11 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
