| Walloper |
 Walloper Super Spammer
 Posted: 23:31 - 21 May 2006 Post subject: |
Might have damaged the seals. Also possible that lying on its side has just allowed air into the brake lines. It is quite easy to get air trapped around the top banjo bolt, and also in the master cylinder depending on the angle it sits at.
Wrap the top banjo up in cloth, pull the lever hard and crack off the top banjo and tighten it up again (the cloth is there to stop the fluid spraying out over everything).
Hopefully that will fix it, but it not try angling the master cylinder such that air will rise to where the piston is in the master cylinder (might need it on the side stand at an odd angle, might even need to take the m/c off). With the cap off try pulling the lever slightly, which often pushes bubbles out from the master cylinder.
| Walloper |
 Posted: 01:23 - 22 May 2006 Post subject: |
Cheerz mucker.
I think it's time to flush out the old fluid then.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Walloper |
 Posted: 21:56 - 27 May 2006 Post subject: |
flushed out old fluid. Tried brake. No better.
Bought a Pressure bleeding kit.
Fitted kit. Pressurized fluid reservoir and ran about 200ml fluid through to both caliper bleeders. No change.
Will pressurize from caliper bleeder next.
| Finglonga |
 Finglonga World Chat Champion
| Walloper |
 Posted: 20:28 - 28 May 2006 Post subject: |
Tried tying back the lever o/night last week.
Bled from caliper bleeder to master cyl res today.
Tried holding the res above the level of the master cyl and flicking,
twidling, piddling and widdling the lever to get air out.
The pile of shite is going to the dealer tomorrow.
I still think the master cylinder copped it somehow in the spill.
I hope to get the real deal from the dealer mechanic.
The bikes useless without a proper brake.
I don't know what the master cyl is made of but may be a mechanical defect allowing the charge of fluid to escape back to the res when the lever is not used for a while.
I know what air in the system should feel like. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 00:04 - 29 May 2006 Post subject: |
| Walloper wrote: | flushed out old fluid. Tried brake. No better.
Probably because theres nothing wrong with the M/C & what you actually did was bugger the disc when it fell over & thats pushing the pistons back at it rotates... |
| Walloper |
| the grim reaper |
 the grim reaper World Chat Champion
| Walloper |
 Posted: 15:56 - 31 May 2006 Post subject: |
I ordered OEM from the dealer. Damn
It was only verbal over the phone to the dealer. So can't really fault them. But I will check this first next time..
I don't have a front paddock stand so never investigated fully. And it was baltic and blowing a mini hurricane at the time.
It's allways the same after you place the order two cheaper options arrive at your door.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
The last post was made 20 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
